07-18-2020, 12:51 PM | #1 |
Drives: 5th Gen L99 Join Date: Nov 2017
LSA conversion results
Hey guys, recently got my car back after doing an LSA conversion. I just wanted to post my results in case anyone is looking into doing one. Also to help anyone else interested I’ll post roughly how much everything cost me.
The kit came with pretty much everything needed including a breakout harness to pull IAT’s at the blower. All we needed was a belt and coolant hose. I did upgrade a few things too. I bought the kit through boost district with FID 1000cc & their upgraded heat exchanger for 5,000 Aux fuel system 1,000 Pierberg intercooler pump 389 Synergy intercooler tank 525 Innovative west 10% lower 550 Innovative west pin kit 75 Grip tech 2.50 upper 200 Might mouse 353 Flex fuel kit 250 Reinforced brick 100 NGK tr7ix 73 91 and E 85 tune 750 Labor 2200 Previous mods- LS3 conversion TSP stage 2 cam Circle D 3200 stall HP series Ported and milled .015 LS3 heads FBO’s The car is Pretty awesome now, this is my first time owning anything boosted! Car made 685/613 on E & 610/571 on 91.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
07-18-2020, 01:07 PM | #2 |
Dyno graph & blower pic
07-18-2020, 01:17 PM | #3 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Did you drill the holes to make access to the rear lid bolts easier?
07-18-2020, 01:18 PM | #4 |
Nice results.
07-18-2020, 01:24 PM | #5 | |
And thank you it turned out well.
07-18-2020, 01:46 PM | #6 |
'It's an experiment'
Nice!
I didn’t have to drill for the back bolts. I’ve had mine off several times and now I just lower the cradle just enough. Congrats! -Don
747 RWHP 794 RWTQ
07-18-2020, 06:51 PM | #7 |
That’s a good idea too. I’ll be pulling it off at some point I’m sure to get ported and maybe the 3 belt system like you got.
07-18-2020, 06:59 PM | #8 |
You are about half way between Vegas and Phoenix. Do you have plans to run it when the weather cools down? Which track would you go to?
07-18-2020, 07:09 PM | #9 |
Vegas is just a bit closer, I’ll be headed your way for sure. Hopefully nothing gets shut down.
07-18-2020, 07:42 PM | #10 |
Let me know, but don't waste your time at Midnight Mayhem events. They don't prep for those. Only do TNT or actual racing events. I'm hoping to get back down in the 9s once it cools down.
07-19-2020, 04:19 PM | #11 |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
How do you like the TSP cam? I did my LSA conversion and cam is next. Debating on brand and stage 2 or 3.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
07-19-2020, 06:13 PM | #12 |
I love the cam, my car sounds knarley. I have a NA cam tho. The tsp stage 2 is bigger than the BTR stage 3 if comparing those two companies. For the TSP NA cams. The stage 3 only makes 4 more hp than the stage 2, that’s why I chose this one. Since you already have the blower I’d get their stage 3 blower cam, or call them and say you want the nastiest PD cam they can make.
07-19-2020, 06:14 PM | #13 |
I’ll definitely let you know when I’m heading to the track.
07-20-2020, 02:17 PM | #14 |
Drives: 2014 SS Convertible Join Date: Jun 2015
What boost level are you at?
Engine: LSA Conversion, Ported Heads, 1 7/8 headers, VMS 2.5 Cam, Roto Fab intake, ADM Scoop. BMR engine mounts, 3.91
628/525 Suspension: Koni orange, (BMR everything) 1" drop springs, toe rods, trailer arms, non adjustable LCR, FE4 sway bars, sub frame connectors, delrin sub frame bushing and upper control arm bushings. Front bushings. |
