Old 07-18-2020, 03:24 PM   #1
Vicster
Vicster's Avatar
Drives: 13' ZL1
Talking Question: Comp Cams BSR Rocker Arm System
Hello,
Has anyone installed the Comp Cam Max-Lift BSR Shaft Rocker System? I want to upgrade to it but I cannot find where anyone has installed the pressurized oil feed to it. I asked Comp Cams but only got this as an answer. "They are set up for -4 AN o-ring style fitting. We have never tested or figured any way to actually provide the oiling. It was just a simple option to add." And a second email I got this reply. "Like I said, we never tested or actually tried to make it work on an engine. It was just a simple add on to machine the threads in the bar to allow for it if someone wanted to do it. It never went beyond that." So comp cams has not even done this... I realize that it is not a must do to add the pressurized oil to it, but want to look into doing it.
Vicster is offline   Reply With Quote
Old 07-24-2020, 03:40 PM   #2
Vicster
Vicster's Avatar
Drives: 13' ZL1
Arrow There has to be someone
There has to be someone that has installed these and tried or thought about adding the pressurized oiling to them.
Old 07-24-2020, 04:00 PM   #3
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
Why would there be anyone? Stock rockers with trunion upgrade is a great option for 99.99% of cars. You would need some way to tap a oil way Or a pump to get oil to shaft and go through the valve covers to a port on the block ... oil doesnt run through A passage in the heads so you cannot tap and hook it up under the valve cover
Crash76 is offline   Reply With Quote
Old 07-30-2020, 05:28 AM   #4
Vicster
Vicster's Avatar
Drives: 13' ZL1
Thats what I thought
That's what I thought, I am using CHE's trunnion upgrade bushings. I was thinking of installing a tee on the oil pressure sensor on the back of the valley cover and running it through the valve covers.
These are stock rockers on a one piece bar, with a layered bushing inlay.
Just wanted to see if anyone had done it...
Old 07-30-2020, 06:58 AM   #5
Crash76
Team 913
I doubt there is any need for shaft mount rockers unless you go with a nasty solid roller cam
Old 07-30-2020, 08:45 AM   #6
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Really?
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 07-30-2020, 09:01 AM   #7
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
Originally Posted by Clarkstar View Post
Really?
Dayum
How’d that happen
Risingson05 is offline   Reply With Quote
Old 07-30-2020, 09:09 AM   #8
Crash76
Team 913
Really?
What does that have to do with shaft mounts? The head of the arm broke off ... either bad material or too aggressive a cam, wrong push rod length.
Upgrading a rocker arm to a shaft mount system is not the same as going to a billet rocker arm...
I had T&Ds on my 409 Solid Roller 4th gen , yella terras with an aggressive hydro roller ...
You had some bad luck with that rocker arm... hopefully it didnt cause too much damage to your motor.
Old 07-30-2020, 09:11 AM   #9
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
I think he had to buy a new motor.
JB'sZL1 is offline   Reply With Quote
Old 07-30-2020, 09:15 AM   #10
SS Performance
SS Performance's Avatar
Drives: 02 Camaro B4C
On the Corvette forms some people have used them. I think they are more popular on the LS7's.
I installed them on my dedicated track day car that uses LS7 heads.
Haven't fired the engine yet. One reason I went with them was I needed rocker arms and the expense of buying rocker arms and trunnion up grade was about the same as buying these. I also figured the extra stability for an engine spending a lot of time in the higher RPM's was a benefit.
A man's garage is his castle
1969 Camaro SS
1970 Camaro SS
2002 Camaro B4C
2014 Camaro SS Dedicated Track Car
2015 Camaro 1SS 1LE
2008 HHR SS
1996 Silverado Crew Cab Long Bed Dual Rear Wheel
SS Performance is offline   Reply With Quote
Old 07-30-2020, 09:27 AM   #11
Clarkstar
Clarkstar's Avatar
No damage to the motor. Had to get a new retainer and locks
Old 07-30-2020, 09:46 AM   #12
JB'sZL1
My mistake. I made an assumption because of the 416 in your sig.
Old 07-30-2020, 11:09 AM   #13
Clarkstar
Clarkstar's Avatar
Spun a rod bearing on the stock motor....
Old 08-07-2020, 09:11 PM   #14
Vicster
Vicster's Avatar
Drives: 13' ZL1
Cool WoW
Really?
Never thought the rocker would break like that...
