![]() Drives: 2013 2SS/RS Blue Ray convertible Join Date: Feb 2020
Rear tire size on 2013 2SS
Hey,...any advise on the max rear tire size for stock 20" wheels on my 2013 2SS?
I am looking at replacing tires and would like to put the max rear tire size without rubbing or significant speedometer inaccuracy. The stock rear tire is 275 /40R20. How big can I go? |
![]() ![]() ![]() Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
zl1's had 305/35's on the rear. i don't know how much rubber you can put on a 9.5 inch wide wheel
i'm sure you can do 285/35's.https://www.discounttire.com/?&ef_id...itment/vehicle |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
275 is pretty much max. Some have done larger, but not recommended.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 LT1 / 19 Z06 / after 6 5th gens Join Date: Jan 2014
If you plan on staying with stock size rim, then I personally wouldn't go above 285 (I had 285s on 9.5 rear). Some guys push up to 305, but consider your sidewall sizes and how you plan on using the car. Best bet, stick with what works. Also, from personal experience, depending on tire manufacturer at least in 17 or 18" sizes, 285s are a pain to find (maybe more readily available in 20s, I don't know).
Go 11s in the rear and go nuts safely with wider tires, maybe not a bad time to consider this while looking for tires anyway.
"Make yourself sheep and the wolves will eat you"
Drives: 2014 camaro SS Join Date: Jan 2019
305
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
tire shops are going to tell you don't do it
forum's same thing don't do it I've been running 275 40 20's on the front and 315 35 20's on the back for at least 2 years No Problems Last edited by spyderbuddy; 07-18-2020 at 08:15 PM. |
#7 |
Jedi Master
Drives: Boeing 757/767+2010 IBM 2SS Join Date: Aug 2008
375 40s huh......no you haven’t
#8 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
#9 |
#10 |
#11 |
![]() Drives: 2015 Camaro SS Join Date: Oct 2019
lol
#12 |
they make em in a 24 https://simpletire.com/tire-sizes/lt375-40r-24-tires
i just posted my pics up today of the 20x10+35 with 275/40's.it's close with that offset i wouldn't want to go any larger on the front. on the back a 305 would have been nice. that being said give the 305's a shot. 305's are around double what a 275 costs. what are you looking for summer or all season? |
#13 |
Just in Case
#14 |
Everybody is saying go with a Square Setup
The Z/28 & ZL1 boy's know what i mean Suppose to take the understeer out. not sure |
