Old 07-20-2020, 04:08 PM   #1
jaysrippen
jaysrippen's Avatar
Drives: 2010ss M6 LS3
Quick LS3 cam question please, Summit stage 3
I know guys are tired of cam questions but searching and google searching I didn’t answer question:
Will Summit stage 3 ls pro cam still be streetable? I just have Low speed Drive ability concerns! M6 2010 ss
Stage 3 Pro LS Cam - Extra Valve Clearance Version, 230/242 113+3, .625/.605 Lift, Excellent power and torque, 3-bolt, 5.3, 5.7, 6.0, 6.2, 7.0L
jaysrippen is offline   Reply With Quote
Old 07-20-2020, 05:21 PM   #2
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
A good tuner can make that street able no problems
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 07-20-2020, 06:15 PM   #3
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
What Dave said, that’s actually a mild cam compared to others I’ve seen put into an LS3. A good tuner will have no problem with it.
HOJO is offline   Reply With Quote
Old 07-22-2020, 06:49 PM   #4
KW Baraka
KW Baraka's Avatar
Drives: 2014 Chevy SS
Originally Posted by jaysrippen View Post
.....Will Summit stage 3 ls pro cam still be streetable? I just have Low speed Drive ability concerns! M6 2010 ss
Stage 3 Pro LS Cam - Extra Valve Clearance Version, 230/242 113+3, .625/.605 Lift, .........
My daily drive Impala SS with LS3 has the Lingenfelter GT1-1 cam;
229*/242*, 114* + 0*.
That Summit cam has about 3* more overlap. Still....a good tuner should be able to control that cam.
Personally, If I were to do it all over again, I'd go with the BTR Stage 3, LS3 Cam;
229*/244*, 113* + 4*.
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4
2014 Chevy SS --- 429ci Hydraulic Roller LS3
KW Baraka is offline   Reply With Quote
Old 07-22-2020, 09:02 PM   #5
dino2012ls3
Drives: 2012 ls3
What's streetable? I run .236/.242 with manual with over 40k on build. No problems and oh have over 100k on car.
dino2012ls3 is offline   Reply With Quote
Old 07-22-2020, 09:26 PM   #6
Bo White
Bo White's Avatar
I daily a 243/255-111 but I'm not a manual anymore.
Old 07-24-2020, 10:02 AM   #7
jaysrippen
jaysrippen's Avatar
thanks guys, good info
Old 07-24-2020, 01:34 PM   #8
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
I daily a 242/260 -111 manual... i don't have any problems. My wife won't drive it though...lol
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
