Old 07-23-2020, 07:45 PM   #1
theragtopguy
Lifetime Philly Fan
theragtopguy's Avatar
Drives: 2015 Spring Edition 2SS M-6
Oh no Window issue!
I put the driver’s window down and heard a ka-thunk inside the door. Window went up again, that’s it. I can hear the motor run.
I am thinking the regulator fell out??
Hope this door isn’t too bad to take apart.
Ugh
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter
BBK LT HEADERS 1 7/8”
Tune by DynoSteve via SCTx4 Tuner
One of 82 GF Ragtops built in '15 out of 811 Total
[/SIZE]
theragtopguy is offline   Reply With Quote
Old 07-23-2020, 10:09 PM   #2
ElderJ
ElderJ's Avatar
Drives: 2014 Camaro 1LT
How many miles, just out of curiosity?
ElderJ is offline   Reply With Quote
Old 07-23-2020, 11:11 PM   #3
theragtopguy
Lifetime Philly Fan
45K.
[/SIZE]
Old 07-24-2020, 12:37 AM   #4
InFiD3ViL
InFiD3ViL's Avatar
Not too bad. 5 bolts/screws total holding the trim panel on.
2 phillips screws on very bottom of door, 1 phillips in upper hinge area, one 7mm behind plastic trim plate (pop off with flathead or pry tool) behind the door opener handle, and a larger hex bolt underneath the rubberized trim piece in the arm rest. The panel is held on by plastic push tabs. Just start in one area with a trim tool and pop it off slowly.
It is also held in the top part near the window by metal tabs, so you just pull the panel out towards the interior once you have the door lock popper removed from the panel by lifting the panel a little bit. I suggest you remove your tweeter before you try to get the panel off. The tweeter will pull right off if you pull straight up. Finally, you have a black vapor shield that needs to come off for access, held on by a rubber or hot glue stick type glue. Greater access will be had by removing the speaker too.
Once you have to door panel off, I suggest you have a helper to hold the panel while you disconnect all the harness connectors. The door release cable comes off easy with a flathead screwdriver and it's release tab is bright green.
Replacing the regulator is very easy. But just make sure that is your issue first. Also, I would try and make sure the window is fully up before you do this as access is limited with it down.
Old 07-24-2020, 01:32 AM   #5
theragtopguy
Lifetime Philly Fan
Thanks, doesn’t sound too bad.
[/SIZE]
Old 07-24-2020, 01:32 PM   #6
theragtopguy
Lifetime Philly Fan
Debating whether to do this myself or not. Dealer just gave me a cost of just under $500 to put a new one in.
[/SIZE]
Old 07-24-2020, 02:57 PM   #7
Excavator3000
Drives: 2015 Camaro SS
dayum
Excavator3000 is offline   Reply With Quote
Old 07-24-2020, 03:24 PM   #8
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
door panel is pretty easy to take off. take it off and take a look at it. then go from there.
Old 07-24-2020, 10:06 PM   #9
theragtopguy
Lifetime Philly Fan
Ah, I’m gonna take it in. I have the bread and since it’s a rare Green Flash I want it done right. My arthritic fingers aren’t up to it.
[/SIZE]
Old 07-26-2020, 12:46 PM   #10
Glassman66
Glassman66's Avatar
Drives: 2014 Camaro 2SS/RS 1le
Regulators are pretty easy. Just take it apart and put it back together, if you can turn a wrench, you got this.
https://www.camaro5.com/forums/image.php?type=sigpic&userid=124840&dateline=15563  941302014 Camaro 1LE SS/RS THE MISTRESS
Glassman66 is offline   Reply With Quote
Old 07-29-2020, 04:21 PM   #11
uvraise
uvraise's Avatar
Drives: 2021 Camaro SS Convertible
Ugh
It's the cable on the regulator, it's very thin and they rust out, at least they did in my vert.. I'm not an expert on these cars or any car for that matter, but I do most of my own work with the exception of tear downs and transmissions, I attempted to get the old regulator out, but gave up after multiple cuts and scrapes due to my big hands and ended up taking it to the dealer, $350. Be prepared to do the other side within a year.
2015 SS2/RS, SCT Tune (Dynosteve), Vitesse Throttle Controller, Vararam VR-DRX CAI, Vararam Power Wedge TBS, Granatelli Performance MAF
uvraise is offline   Reply With Quote
Old 07-29-2020, 09:43 PM   #12
theragtopguy
Lifetime Philly Fan
She is at the dealer now. Waiting for the regulator.
[/SIZE]
Old 07-29-2020, 11:11 PM   #13
InFiD3ViL
InFiD3ViL's Avatar
It's actually fairly easy. But the problem is the window MUST be in the full up position or you can't access all the bolts, which makes it difficult if you are already having window issues.
But I can definitely see it being a problem for someone with big old meat hooks. There is a lot of sharp edged sheet metal in these doors.
