Old 07-24-2020, 06:59 PM   #1
Maroon 6.2L SS
Maroon 6.2L SS's Avatar
Drives: 2010 Camaro SS A6
Distance between stage and deep stage
I believe it is roughly 7" between activating the pre-stage light and then the stage light.
Does anyone know the distance between activating the stage light and turning off the pre-stage light? (deep staging)
2, 4" ???
Maroon 6.2L SS is offline   Reply With Quote
Old 07-24-2020, 09:59 PM   #2
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
https://www.onallcylinders.com/2012/...your-drag-car/
Looks like about 6”
joshnmn is offline   Reply With Quote
Old 07-24-2020, 11:02 PM   #3
Silveradoss573
Banned
Drives: Camaro 1LE
5" give or take a inch depending on how each tracks system is set up.
Silveradoss573 is offline   Reply With Quote
Old 07-24-2020, 11:27 PM   #4
JimCT_9C1
JimCT_9C1's Avatar
Drives: 2012 Caprice PPV
It depends on your tire diameter.
When staging, you turn on the stage light by breaking the stage beam with the front edge of the tire.
When deep staging, you keep rolling through until you turn off the prestage bulb by "un-breaking" the prestage beam with the back edge.
Either way, the ET timer starts when the stage beam is "unbroken" by the back edge of the tire.
Hope this helps,
Jim
2012 Caprice PPV 9C1 L77 6.0 6L80E
OTR Intake, JBA Exhaust, More to come...
JimCT_9C1 is offline   Reply With Quote
Old 07-24-2020, 11:33 PM   #5
Silveradoss573
Banned
Drives: Camaro 1LE
Hope this helps,
Jim
This too...yes
Old 07-24-2020, 11:43 PM   #6
JimCT_9C1
JimCT_9C1's Avatar
Sorry - I got ahead of myself in the above response. Deep staging takes tire diameter out of the equation. Tire diameter otherwise is a factor.
Since the back edge of the tire both sets the stage depth and starts the ET clock, the rollout distance is always the same and equal to the separation of the beams.
Jim
Edit: I answered two different questions. Tire diameter does affect how far you roll into the beams after staging until you are deep staged. Once deep staged tire diameter does not affect rollout
