Old 07-29-2020, 12:27 AM   #1
L6611983
Drives: 2010 Camaro 2SS
Subwoofer box
I can't seem to find the subwoofer box for 12 inch subs online anywhere , any help would be appreciated.
L6611983 is offline   Reply With Quote
Old 07-29-2020, 03:55 AM   #2
Deftones
Deftones's Avatar
Drives: 2012 RS/SS LS3
Try sub_thump.cøm
Deftones is offline   Reply With Quote
Old 07-29-2020, 10:21 AM   #3
Athletics101
Athletics101's Avatar
Drives: 5th Gen L99
If you can build a box you will have better results. That way you can build it to match the air requirements of the subs you are buying.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
Athletics101 is offline   Reply With Quote
Old 07-29-2020, 12:37 PM   #4
SSkat
SSkat's Avatar
Are you set on sealed? If you want ported go single sub. I have a (s)ub (t)thump single ported 12 with 600 watts and it slams. They also sell sealed boxes.
SSkat is offline   Reply With Quote
Old 07-29-2020, 12:38 PM   #5
SSkat
SSkat's Avatar
Originally Posted by Athletics101 View Post
If you can build a box you will have better results. That way you can build it to match the air requirements of the suns you buy.
Also dont mean to highjack but Athletics are you the car on Boostdistricts instagram?
Old 07-29-2020, 12:45 PM   #6
Athletics101
Drives: 5th Gen L99
Yes sir.
Old 07-29-2020, 01:09 PM   #7
byrds8
byrds8's Avatar
Drives: 2013 Camaro 2SS, L99
I got my box from a different vendor that the one mentioned above but it has 2 10" in it with a 600W amp. Its a sealed box and has tons of bass. I would say you can give their custom boxes a look but the website says they are closed atm. Not sure why.
2013 Camaro SS/RS, Stainless Power long tube headers with HF's, Air Raid CAI, Solo Mach XL cat back, BC Racing coil overs, Elite Engineering catch can, Ferrada Forge 8 Wheels, Windows tinted at 20%, Tuned by Dyno Steve.
byrds8 is offline   Reply With Quote
