Old 07-29-2020, 10:50 AM   #1
OutlawPerformanceGarage
Drives: ZL1 Camaro, Procharged Silverado,
Overdrive calculation?
I’m trying to figure out how much overdrive I will be putting on my supercharger ported by Kong’s Performance Greg. I am running a 9.45 lower and a 2.35 upper pulley. Going in for a new Dino this Friday and I was just wondering how much overdrive I’m producing. Any info is much appreciated https://www.camaro5.com/forums/attac...1&d=1596036362
OutlawPerformanceGarage is offline   Reply With Quote
Old 07-29-2020, 10:54 AM   #2
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
That appears to be approaching 26k...might want to back off a little.
https://www.lingenfelter.com/PDFdown...lt%20Sizes.pdf
JB'sZL1 is offline   Reply With Quote
Old 07-29-2020, 12:15 PM   #3
So in total with the upper pulley and lower pulley what do you think the overdrive percentages is? Somebody told me it’s like 50% overdrive combined upper and lower. Do you think this is true?
Old 07-29-2020, 02:25 PM   #4
gtstorey
You will have a pulley ration of 9.45/2.35=4.02
Stock Pulley ratio from Linenfelter Chart 7.8/3.0=2.6
(4.02-2.6)/2.6=55%
Old 07-29-2020, 05:17 PM   #5
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Bingo! Most people run about 38% to 42% maximum. Some push it to 44%, but not many people (ZL1 or CTS-V) go up to 55%!
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // BMR MM // BC Forged KL13
Mods being installed-
oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc.
RobZL1 is offline   Reply With Quote
Old 07-29-2020, 05:37 PM   #6
Vegas Bound
Drives: 2013 Sparkly Red One
I've been running 44% for over 7 years.
Vegas Bound is offline   Reply With Quote
Old 07-30-2020, 11:19 PM   #7
Damn so what do you think? Do you think I’m in bad shape here.? I seen one other dude doing on the stock bottom man on YouTube and he made 830 to the wheel with stock heads stock bottom end. Do you think I should stop tuning at 5500 RPM?
Old 07-30-2020, 11:21 PM   #8
Thank you man I appreciate that. 55% is a lot. I’m going to hit the Dino this Friday right now we’re at 7:40 to the rear wheel and the only thing that I’ve changed was ATI super damper the 9.45 lower pulley and a custom 5 inch intake with 3 inch exhaust all the way back. Do you think this is a bit much for the car to handle?
Old 07-30-2020, 11:22 PM   #9
Vegas Bound
Hell no, I'm pushing to 7200 rpm. However, I would step down to a 2.55 upper.
Old 07-31-2020, 08:41 AM   #10
JB'sZL1
I've stated my opinion. You'll always find some saying they've pushed it to 18lbs. or 26.5k. The safe zone is 15, no more than 16 lbs. and 23k. Period.
Old 08-22-2020, 07:45 PM   #11
leemozoid
leemozoid's Avatar
Drives: '15 Silverado LTZ & '13 ZL1 ragtop
I'm running 38% but that's still only 13 psi boost. All else being equal in a good build that's hardly an engine killer.
HP tune, Kooks 1 7/8" LT w/ cat deletes, FIC 1300 inj, E85, GPI SS3 blower cam, Fore Innovations Gen 5 dual pump module with twin TI Automotive 430 lph E85 compatible pumps, Lingenfelter 10 bolt 2.55" upper/9.17" lower pulleys, AFCO triple pass intercooler with dual fans, Killer Chiller interchiller, B3R insulated expansion tank, full BMR rear drag cradle and suspension, DSS one piece driveshaft and Stage 5 billet axle shafts, Rotofab CAI, reinforced brick, Devil's Own progressive methanol injection, FTI 9.5" billet lock up Street Racer torque converter, 3200 rpm stall, triple clutch.
leemozoid is offline   Reply With Quote
Old 08-22-2020, 09:19 PM   #12
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
I may be misinterpreting your comment, but I don't think it's about boost pressure killing the engine. I think it's more about critical speed of the bearings and rotor assemblies killing the blower...and maybe killing the engine.
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
boost, lsa, overdrive, zl1
