Old 07-30-2020, 02:07 PM   #1
CaliforniaSS
CaliforniaSS's Avatar
Drives: 2010 Chevy Camaro 2SS
Mickey Thompson ET Street S/S at the strip
Just got some 17x9.5 racestars and the street ss in 305/45 /17 . Mounted and balanced out the door at $1250. I have a stock M6 2010 camaro ss. The tire guy said a slick would snap my axel(do not want lol) This would be my dedicated track setup. Wanted you guys' opinions about psi, launch rpm , and hook for the track. After doing some research the street ss might not be the best for a manual tranny? I called mickey thompson and the guy that answered the phone said those would not hook well on a manual tranny with my heavy chevy 😞
CaliforniaSS is offline   Reply With Quote
Old 07-30-2020, 03:03 PM   #2
IWANTA(ss)
IWANTA(ss)'s Avatar
Drives: 13 1LE 1SS/05 ZX10/02 Silverado/14
I thought the radials snaps axles and the slicks were best for manual trans
02 Stepside Silverado
05 ZX-10
13 1LE
14 Nightrod Special
IWANTA(ss) is offline   Reply With Quote
Old 07-30-2020, 04:05 PM   #3
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
Either tire can snap an axle if the conditions are right and you dead hook. Slicks will have a lot of sidewall flex (DRs dont have much at all if any) and that helps lower the shock on the drivetrain from a manual launch so i would think they are less likely to snap things.
2014 1SS/1LE
AGP 57/57s, E85 + meth injection, Monster triple, ZL1 diff swap, Z28 coilovers
AGM 1LE is offline   Reply With Quote
Old 07-30-2020, 04:51 PM   #4
IWANTA(ss)
IWANTA(ss)'s Avatar
Yea I knew the but the op was saying he was told it was the other way round
05 ZX-10
13 1LE
14 Nightrod Special
Old 07-30-2020, 07:53 PM   #5
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
Fur sure man. I was just giving a little bit of the science behind the whole situation
2014 1SS/1LE
Old 07-30-2020, 09:07 PM   #6
Vegas Bound
Drives: 2013 Sparkly Red One
Should have got Hoosier bias ply slicks for the manual trans. Now that you are stuck with the MT SS, I'd start around 22-23 lbs and drop a lb until you hook. I ran 17 lbs with slicks/manual and run 17.5 lbs with DRs/auto now.
Vegas Bound is offline   Reply With Quote
Old 07-30-2020, 11:28 PM   #7
Tajefe Couple
Tajefe Couple's Avatar
Drives: Never just fly under the radar
Curious what drag radial are you running now?
I was looking at the DOT Hoosier Quick Time Pro 28x11.5 bias(only a 24lb tire), but seems everyone likes the MT. I have M&H 325/45/17 DR and they where good enough for a 1.5 60' last season but have seen better days. Just trying to decide the best tire for these heavy auto cars.
Thoughts?
Old Skool
Tajefe Couple is offline   Reply With Quote
Old 07-31-2020, 12:10 AM   #8
Vegas Bound
Thoughts?
I run MT ET Street R 305/45*17 currently. I am planning on replacing them with MT ET Street R 315/50*17 and adjusting my coil overs accordingly. It will give me an adjusted final ratio of 3.50 from 3.73 with the extra 1.5" of tire diameter. Also bigger contact patch and more sidewall.
Old 07-31-2020, 12:34 AM   #9
Tajefe Couple
Appreciate it!
So going to a 29.4" tall tire doesn't turn on all your dummy lights or go in to "limp mode"? Or do you pull the ABS fuse and call it a day?
Just asking since I have 28's up front and seem to remember something being said about staying within an inch of those to avoid problems.
I have adjustable coilovers but lowered down so maybe not the route for mine
Old Skool
Old 07-31-2020, 12:49 AM   #10
Vegas Bound
I would pull the 2 fuses just as a precaution. I have seen a guy run 28 front and 29.5 rear with no problems but why not be safe just in case. I would lose my electric power assist steering while the fuses were out.
I have adjustable too. Raising them up would help with camber for launch. And if I count correctly, I can drop them back down for street tires without need for alignment.
Old 07-31-2020, 01:00 AM   #11
Tajefe Couple
Be interesting to see how it turns out for you!
I have 3.91s so think it would put me somewhere in the 3.74 range going to the 315/50*17. I'm really running out of gear on the big end right now unless I pull it out pretty far in 4th.
Old Skool
Old 07-31-2020, 01:20 AM   #12
Vegas Bound
I'm 4L80e, so I am maxing out around 1200 ft. The 315s would get me through the entire 1320.
1/8 would be just shifting 2 to D as I cross the beams.
Old 07-31-2020, 03:11 AM   #13
IWANTA(ss)
IWANTA(ss)'s Avatar
I was in the same boat as him a few weeks ago and I ended up with the m&h slicks. After doing some searching
05 ZX-10
13 1LE
14 Nightrod Special
Old 06-02-2021, 01:38 AM   #14
CaliforniaSS
So the mickey thompson street ss hook up really well and ar stickyyyy. Love them . 10/10 would buy again
13.2 stock
12.94 CAI & MT Street SS
