Old 07-31-2020, 12:20 PM   #1
Havok1105
Drives: 2011 Camaro 2SS Convertible Auto
Oil Catch Can
Hey I have a 2011 SS auto, i want to get a catch can but don't know which one is the best one, and since I get my oil changed at a valvoline will there be any trouble with it?
Havok1105 is offline   Reply With Quote
Old 07-31-2020, 12:45 PM   #2
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
Truthfully on a stock L99, not worth it.
But if you wanted one, I would suggest the Elite Engineering. I wouldn't even bother having a quick oil change place empty it, just unscrew it yourself every now and then and empty the contents into a container. When you fill the container, bring it with you to your next oil change and just ask them to dispose for you.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 07-31-2020, 02:01 PM   #3
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
I have the mishimoto one and it was a easy 10 min install and catches a good amount. I empty it out once a month and remove a decent amount of blow by.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 07-31-2020, 02:22 PM   #4
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
there is only one catch can worth buying....mighty mouse.
Apex VS-5RS Forged Wheels,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 103mm TB, Dr Phil Tune,Borla Atak...955rwhp/967rwtq
gm2376 is offline   Reply With Quote
Old 07-31-2020, 06:58 PM   #5
InFiD3ViL
InFiD3ViL's Avatar
I have heard good things about them, but I don't know about all that.
I do know if I was boosted it would almost certainly be who I would go with though.
Old 07-31-2020, 08:11 PM   #6
Vegas Bound
Drives: 2013 Sparkly Red One
That's what I have.
Vegas Bound is offline   Reply With Quote
Old 07-31-2020, 08:21 PM   #7
BAD DAB
BAD DAB's Avatar
I have Elite catch can.
Old 07-31-2020, 09:01 PM   #8
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
I went with Mighty Mouse .
Risingson05 is offline   Reply With Quote
Old 08-01-2020, 01:23 AM   #9
'10CamaroDude
Drives: 2010 Camaro LS
$18.00 - Ebay:
Clone of one of the good ones, just isn't as long. My PCV line to the intake
manifold is DRY, so it works, hands down.
'10CamaroDude is offline   Reply With Quote
Old 08-01-2020, 05:57 PM   #10
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
JLT makes a good can. Im running it and it works well. Literally takes 5 min to install and very good quality
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 08-15-2020, 09:40 AM   #11
Dieselsmoke
Dieselsmoke's Avatar
Drives: 2010 2SSRS 6 speed Victory Red
I have the Mishimoto catch can. I liked the mounting of this unit also has a drain plug on bottom that I added a 1/8" fomoto oil drain valve to, no need to unscrew the can anymore to drain u will be amazed how much comes out that would be going back in to be burned.
Dieselsmoke is offline   Reply With Quote
Old 08-15-2020, 12:01 PM   #12
MeanV8
Drives: Chevy Camaro SS, Chevy Corvette,
Elite Catch Can here!
Dan
MeanV8 is offline   Reply With Quote
Old 08-16-2020, 08:51 AM   #13
mbesman
Great White
mbesman's Avatar
Drives: 2015 Camaro 2SS
Mishimoto worked for me. Easy Install. 15 minutes.
mbesman is offline   Reply With Quote
Old 08-16-2020, 09:01 AM   #14
Mauimax3
Mauimax3
Mauimax3's Avatar
Drives: 2013 Camaro SS
Thumbs up
Good lookin engine bay...
Magnuson Supercharger, ZL-1 Fuel Pump, Kenny Belle Boost-a-Pump, Kook's LongTube, BTR Stage II, Trunion upgrade, ATI Superdampner, Nick Williams 102mm, Elite Eng. Can, Borla ATAK exhaust w/flow thru cats, CAI box. BMR Suspension upgrades. Dr Phil tuned.
Mauimax3 is offline   Reply With Quote
