Old 08-01-2020, 05:46 PM   #1
Marknbacon
Drives: 2015 camaro SS
Cam Decisions...
Alright, I'm going to be ordering my cam hopefully in the next month and I have a decision to make. I'm pretty sure I've got it narrowed down to three. I would LOVE to see videos of how your car sounds with these exact cams if you have them, and maybe some input on general drive-ability and satisfaction.
Option 1: Comp Cams XFI extreme energy-R 224/230 (SKU 51-444-11, aka XER273HR)
Specs: (@.050 duration) 224 intake, 230 exhaust, 114 LSA, lift (in/ex) .581/.588, intake centerline 112.
Option 2: GPI SS2.
Specs: 228/240, LSA 112, lift .646/.637, ICL +4.
Option 3: TSP N/A stage 2
Specs: 229/224, LSA 112, lift .629/.615, 112 LSA, ICL 109.
Right now the car is pretty much stock but when I put the cam in I am planning on putting kook's long tubes w/ HF cats as well.
Let me know what you think.
Thanks guys!
Marknbacon is offline   Reply With Quote
Old 08-01-2020, 08:12 PM   #2
Quicksilver-SS
Quicksilver-SS's Avatar
Drives: 2014 1SS / RS M6
Search youtube. You will get better results.
Quicksilver-SS is offline   Reply With Quote
Old 08-02-2020, 12:23 PM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
You tube has a lot of vids, and after years of looking and listening to them went with a TSP Stage 3,,,231/246 @112 LSA , love it, been in the car for 14k miles...
Old 08-02-2020, 10:34 PM   #4
Athletics101
Athletics101's Avatar
Drives: 5th Gen L99
Option 2: GPI SS2.
Thanks guys!
I have the TSP stage 2 NA cam, but I can’t post the video. PM me and I can get you a video. My car sounds knarley.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
Athletics101 is offline   Reply With Quote
Old 08-03-2020, 12:19 AM   #5
Vegas Bound
Drives: 2013 Sparkly Red One
I have never heard of sound being the deciding factor in a cam. I thought it was supposed to be performance.
Vegas Bound is offline   Reply With Quote
Old 08-03-2020, 07:13 AM   #6
RupertPupkin
Drives: 2014 Camaro SS 1Le
Gotta sound fast fast...
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 08-03-2020, 07:27 AM   #7
Marknbacon
It’s definitely not. But there is a certain sound I’m actually trying to avoid.
Old 08-03-2020, 08:08 AM   #8
Marknbacon
And I’m also interested to hear how driving with them has been.
I’m actually leaning towards the less aggressive of the three, the COMP.
Old 08-03-2020, 10:13 AM   #9
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
Idk if you know and if you do I apologies . But I would hope your gonna do a trunion upgrade . Hate to see all your good work go bad, there’s also more than just putting a cam in too . Push rods springs retainers etc.
Risingson05 is offline   Reply With Quote
Old 08-03-2020, 10:43 AM   #10
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
I know NA is different than boosted. I have a stage 2 on my Z and it is more than enough. A little surging and bucking...I can't imagine having a stage 3 in my Z in the city.
JB'sZL1 is offline   Reply With Quote
Old 08-03-2020, 09:32 PM   #11
Marknbacon
Oh yes. Most certainly. Planning on BTR duals with hardened pushrods and probably just steel retainers (might go with comp’s tool steel. Haven’t made up my mind yet) and planning on CHE trunnion upgrade if I can find someone that has them in stock.
I already have some of the basics here or on the way like a new cam retainer plate and ARP balancer bolt.
Old 08-03-2020, 11:30 PM   #12
RupertPupkin
I have a big cam, and it drove like butter before my clutch and FI install.
730whp: 630Trq
Old 08-06-2020, 02:04 PM   #13
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
Option 2: GPI SS2.
Thanks guys!
Driveability will depend much more on the tuner rather than the cam itself (at least for the 3 you are looking at)
Whichever cam you go with, the higher the LSA, the smoother the idle will be. Just something to keep in mind
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 08-06-2020, 02:38 PM   #14
InFiD3ViL
InFiD3ViL's Avatar
Mark, I have ALMOST the same cam as that GPI SS2. Mine (GPI SS1) has the exact same lift, but slightly less duration @ 224/237 and 7º overlap. Are you L99 converting to LS3 or are you a manual car? Because If L99 I would suggest a convertor with the #2 or 3 cams you listed. Although mine is 'only' a stage 1 cam, it's no slouch (especially compared to other companies Stage 1 cams) and causes quite a bit of push at red lights and stops. The car shakes and lopes like crazy in traffic. Personally I love it this way, but I will seriously benefit from a convertor install. I had very little bit of loss on the low rpm end, but nothing too bad. Top end pulls like a beast...but I'm not done yet. Mine was an L99 car but I swapped in a rebuilt LS3 last year and am still running with the 6L80e auto trans on a stock convertor (for now).
So my guess with the SS2 is you can expect a little bit more lope than this (video), otherwise it should be fairly close, at least for comparison's sake. I asked Ryan to tune the nastiest lope he could while keeping it streetable/tolerable...and boy did he!
Here is mine on the final GPI/Ryan remote tune on a cold start and then closed loop idle. I believe it was the 8th revision of the tune that got it to idle like this. I highly recommend listening to a lot of people here's advice on this topic. Do your research and consider your ultimate goals and how these different cams factor into your overall plans. The reason I say this is because people told me my cam would push, that I would want a convertor/gears, etc. with this cam and to just go bigger. I didn't listen. While I love my cam, I already kind of regret just not going with Stage 3 since I am already dealing with these 'issues' and will convertor/gear upgrade later anyway. But I really don't consider any of this as issues or problems. They are just small reminders of why I need to keep modding the car to perfection.
Sorry to those that have seen me post this video multiple times in other threads lol. I need to upload some fresh stuff. It goes into closed loop lopey lovin at around the 1:30 mark.
