![]() Drives: 2011 Camaro 2SS Convertible Auto Join Date: Jul 2020
Stage 1 cam questions
Hi, I have a 2011 Camaro 2SS Auto, LT's, and CAI coming soon. What would I need to do to put a stage 1 cam into my car? I am more looking for the sound it brings idc about the power. I know if you do any sort of cam it brings power I just want the sound from it, so in short, what would I need to get to put a cam into my car?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: ABM #93 Join Date: Oct 2018
For starters You’ll need an afm delete, as well as having the car tuned. Your going to have to pull the heads to replace the afm lifters at a minimum(id seriously consider replacing all 16) You’ll also have to decide if your keeping vvt or deleting it when you order your cam so you can get the right parts either way to do the swap. I’d keep it if I were in your shoes, that’s what I’m doing to mine when the time comes. You’ll definitely pick up power, and at a stage 1 it should still be plenty drivable without a stall converter.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
What are vvt’s, afm lifters, also I’m really trying not to convert it to an ls3
USA-1
VVT is Variable Valve Timing, it's a good thing!
AFM is Active Fuel Management - good and bad thing, but for us having Camaro's bad thing
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
So what I was asking for is more like a list. You know what I mean. I would most likely bring it to a shop near me to install everything. So does anyone have like a list of what I would need
#6 |
![]() Drives: Chevy Camaro SS, Chevy Corvette, Join Date: Aug 2019
I have the same car as you and GPI just finished putting a SS1 VVT Cam with supporting mods and 3.91 rear gears. Believe me the Cam is unbelievable. It really brought the car to life. LCPLPunk is Right Variable Valve Timing is a Very Good thing!!
Dan |
#7 |
USA-1
Havoc, talk with GPI and tell them what you want to do. Expect to pay about $3500ish for cam/parts/install/tune.
#8 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
Here is mine with the LS3 GPI Stage I cam. My car no longer has the L99 or VVT, so this is slightly higher lift/duration than the GPI Stage I VVT cam, but not by much. But for sound comparison's sake I figured I would post it, as it should sound very close to what you are considering. Keep in mind I run one of the louder exhausts you can run on these cars - so volume and tone can be tailored to suit your needs.
It is nice and lopey for a 'Stage I' cam and drivability is fairly good still. But I do certainly plan on a convertor and gears soon. When Ryan from GPI was tuning it I had asked him for more of a natural random lope in the tune, rather than a constant brap brap brap. Closed loop idle lope starts around the 1:30 mark. I need to get a nice rev video soon. I think I had the right side microphone covered a little.
#9 | |
![]() Drives: 5th Gen L99 Join Date: Nov 2017
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
