Old 08-03-2020, 05:38 PM   #1
Maroon 6.2L SS
Maroon 6.2L SS's Avatar
Drives: 2010 Camaro SS A6
gear ratio change and reaction time
Does changing the gear ratio have a big affect on your reaction time? I have the stock 3.27 gears in my auto, and have gotten my reaction time down pretty good. If I switch to 3.91 gears, and keep everything the same with regards to leaving on the tree, will it speed me up enough to where I need to make big changes to my R.T?
Maroon 6.2L SS is offline   Reply With Quote
Old 08-04-2020, 12:44 PM   #2
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Reaction time vs gearing makes no change
ttshovel is offline   Reply With Quote
Old 08-04-2020, 06:47 PM   #3
Maroon 6.2L SS
thanks ttshovel. I put a lot of time in trying to get my reaction time good and I thought that switching to 3.91 gears would make me get out of the hole/off the line quicker causing me to red light a lot.
Old 08-12-2020, 04:49 PM   #4
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Tim Erl had some good comments on reaction times over the years. Takes a fair amount of practice to get into the .0x with our cars.
The gear would help the 60 ft and the overall run though.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 08-12-2020, 04:55 PM   #5
ruby2010
Drives: 2010ss
Ultimately you are the holder of a good reaction time. You can stage a little deeper to shave sometime. i’ve been bracket racing for 23yrs and how a bracket racer stages it’s everything. I know one extra bump i’ll shave a 1/100. Also gearing will change how the car reacts. all things equal , staging , reaction etc your time will be different day between 3.73 and 4.10
ruby2010 is offline   Reply With Quote
