Old 08-04-2020, 10:53 AM   #1
2015FLCamaroSS
Drives: 2015 Chevrolet Camaro SS
Melling oil pump - L99 with DOD and VVT deleted
I completed a cam upgrade on my 2015 Camaro SS 6.2L L99 and removed the DOD and VVT components. While doing so I replaced my oil pump with a Melling M295 pump and I get 28 lbs or pressure hot at idle and approx 50 lbs at 5000 RPM’s. We are about to get back into the engine again, should I switch this pump back to the OEM L99 oil pump? Which pump do I need?
Thank you in advance for your help.
2015FLCamaroSS is offline   Reply With Quote
Old 08-04-2020, 02:51 PM   #2
SSkat
SSkat's Avatar
Drives: 2010 Camaro 2SS
I believe those numbers are right where they should be.
SSkat is offline   Reply With Quote
Old 08-04-2020, 04:25 PM   #3
InFiD3ViL
InFiD3ViL's Avatar
With VVT deleted you are good with those numbers. If you had kept VVT I would have considered the Melling 10296 HV pump. That is what I run and my hot idle is at 42-43 lbs and over 5k rpms I am over 60 lbs. I didn't really need these higher pressures with an LS3 but since the engine came with the pump and it was new, I ran it.
Old 08-05-2020, 07:47 PM   #4
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Getting the same numbers. Cold idle its over 60 after i deleted all that mess. The L99 factory pump is actually a pretty damn good pump
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 08-06-2020, 06:02 PM   #5
JLGO
JLGO's Avatar
Drives: 2015 Camaro SS convertible L99
The melling m296 high volume and stock preasure is put in my VVT3.2 cammed Gen5 years ago. You can keep that melling in there since the car is a no longer VVT.
JLGO is offline   Reply With Quote
