Old 08-04-2020, 09:03 PM   #1
anthony10210
Drives: 2015 camaro 2SS 1LE
REDLINE MOTORSPORTS
Hey guys, I need to get my 1LE tuned asap. Im completely stock for the most part. I have speed engineering headers on the way, a CAI, TR55 plugs, and I have 160 thermostat already installed. I got a quote from the great guys at redline motorsports down in south Florida, its over three thousand dollars, but I've got most of this stuff covered. What do you think I should do? I just want a cam and valve spring install down here in south Florida with decent quality work with parts that I buy; I really want that gwantey performance SS3 cause its badass with the 3.91 gears. Is there anyone from south Florida able to help me install this cam? I'll pay you a bit as well even if its just helping me. Thanks guy! hope you're all doing well
anthony10210 is offline   Reply With Quote
Old 08-04-2020, 09:12 PM   #2
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
Have you called these guys?
https://swfltuningsolutions.com/
Sent from my SM-G975U using Tapatalk
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 08-04-2020, 10:46 PM   #3
anthony10210
I have not, this is the first I've heard of therm. I'll give therm a call, have you heard about any of their work ?
Old 08-04-2020, 10:54 PM   #4
sixty9fordkiller
yeah. lookup @blackjack_ss on instagram.
the owner is on the facebook group too. zachary frederick
Bone Stock
Old 08-05-2020, 01:17 AM   #5
Athletics101
Athletics101's Avatar
Drives: 5th Gen L99
Call faster proms,
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
Athletics101 is offline   Reply With Quote
Old 08-05-2020, 06:49 AM   #6
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
I got my 1LE tuned by them. Stand up people. Cant really go wrong
Old 08-05-2020, 12:48 PM   #7
Roader
Drives: Camaro
Redline is where I’d go down there
Roader is offline   Reply With Quote
Old 08-05-2020, 01:07 PM   #8
SSkat
SSkat's Avatar
Drives: 2010 Camaro 2SS
Zach is moving to the North Carolina this month and is not doing any more work in Florida. He is in the panhandle anyway. You should definetly be able to get it done for under 3k. Mine was 4k with install and tune and im L99.
SSkat is offline   Reply With Quote
Old 08-05-2020, 01:16 PM   #9
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
FWIW, it seems like Howard at Redline is one of the most well-informed calibrators in the industry in my opinion.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // BMR MM // BC Forged KL13
Mods being installed-
oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc.
RobZL1 is offline   Reply With Quote
Old 08-05-2020, 04:47 PM   #10
sixty9fordkiller
Bone Stock
Old 08-06-2020, 10:27 AM   #11
CamaroDreams76
If hes in NC i'd make the drive to Vengence Racing in GA
Old 08-20-2020, 10:42 AM   #12
PhantomBlack
PhantomBlack's Avatar
Drives: 2014 Camaro 2SS
I made a call to Redline before making the trip to GPI for my cam install. Labor was cheaper at GPI so it helped make up some of the funds spent on the trip no regrets.
Mods: GPI SS1 VVT cam, TSP long tube headers, LSA conversion, ZL1 fuel pump, ADM FPCM,
DW 700cc injectors, Lingenfelter solid isolator, Dedicated Motorsports ZL1 reinforced brick,
ADM Griptech 2.5 pulley, JLT CAI, Phastek intake scoop,NPP cat-back,
GM 3.91 gears, Eaton Truetrac, etc.
PhantomBlack is offline   Reply With Quote
cam install, gwatney, south florida, ss3
