Old 08-06-2020, 05:58 PM   #1
Whitlow
Whitlow's Avatar
Drives: Chevrolet Camaro
CLUTCH???
So I took the Camaro out today and was going to just run it through the gears. Took off about 3000 rpms then got into it hard thought it was tire spin but when I went to shift into 2 great I noticed the clutch pedal was only out about half way. Got second and all I could smell was clutch not tires so I let off. What's up with this??
Sent from my motorola edge using Tapatalk
Whitlow is offline   Reply With Quote
Old 08-06-2020, 06:59 PM   #2
Whitlow
Whitlow's Avatar
My car is 2012 SLP585 Supercharged
Old 08-06-2020, 09:32 PM   #3
mikeman
Banned
Drives: 2015 Camaro
If it never did that before, sounds like the clutch is going out. But, I'd change the fluid and do a good bleed first. See what happens then.
mikeman is offline   Reply With Quote
Old 08-06-2020, 09:48 PM   #4
ragtop1
ragtop1's Avatar
Drives: 2012 2ssRS convertible
You can check/search on articles previously posted, but our M6s share the same hydralic reservoir with the brakes. People believe that cross contamination causes the cluch pedal not to return. I have seen both articles that show how to add a separate hydraulic reservoir for the clutch as well as a bracket and return spring that can be added to the clutch pedal.
ragtop1 is offline   Reply With Quote
Old 08-08-2020, 06:25 PM   #5
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I had the clutch pedal stick down at the track. Pulled it back up and drove home. I went to the separate G8 reservoir and never had the problem again.
Old 08-08-2020, 08:29 PM   #6
Whitlow
Whitlow's Avatar
I have a add on reservoir coming tomorrow I'll put it on so a dot4 change and hope for the best! If not I guess I'll be asking about the best clutch to replace mine.
Old 08-08-2020, 09:14 PM   #7
SS Blinder
SS Blinder's Avatar
Drives: 2011 SS (Sparrow Spearer???)
You will get various opinions on the "best" clutch but just make sure you get a remote bleeder and a billet release bearing support
Black magic woman, don't turn your back on me baby!
SS Blinder is offline   Reply With Quote
