Old 08-11-2020, 04:06 AM   #1
Jalouis
Drives: Camry
Cannot stop apple music playlist from auto-playing in car when connected to bluetooth
Annoying problem I cannot solve:
I dont not want to disable data use in music as this seems the only remedy to the problem of apple music starting itself in the car entirely without my permission
free ringtone
Jalouis is offline   Reply With Quote
Old 08-12-2020, 12:01 PM   #2
Stingr69
'69 Owned Since '79
Stingr69's Avatar
I suspect it is running in your phone all the time. My wife has her phone Bluetooth streaming whenever she tries to use her phone to do navigation or other purpose. Pretty annoying but you can stop it if you go into the music app.
Old 08-21-2020, 02:36 PM   #3
trodecke
trodecke's Avatar
Drives: 2014 2SS/RS CRT
I can't speak for Apple Music as I'm an Android type of person but I've run into the same issue in the past. On Android, it's a setting within the app you're using. For me, the latest culprit was Youtube Music but it's moved around. On Android there's a setting that's labeled "Allow external devices to start playback". It mentions Bluetooth and wired headsets as examples. With that enabled, whenever my phone would connect to the BT in my Camaro, it would launch Youtube Music and start playing. Disabling that setting stopped the problem. Like I said, I'm an Android type of person so I'm not sure if there's a similar setting on Apple devices so your milage may vary.
Lifetime Camaro guy. 1979 Z28, 1987 LT, 2012 2LS, 2014 2SS/RS
--CAI Cold Air Intake
--Solo HFC
trodecke is offline   Reply With Quote
