Old 08-11-2020, 04:17 PM   #1
ariZona28
Give speed a chance
ariZona28's Avatar
Splitter Protection
Found a previous thread in the Z/28 section describing the ZL1 Addons metal guards but I'm a little reluctant to drill into my cars snout and install the rather medieval looking devices. Has anyone installed the SLIPLO protectors? They have a complete set-up for splitters and ground effects. A little pricey but might be worth it.
ariZona28 is offline   Reply With Quote
Old 08-13-2020, 12:10 AM   #2
LT1Zob
LT1Zob's Avatar
Drives: 23 LT1 / 19 Z06 / after 6 5th gens
Was going to recommend Sliplo, but I see you already know about it. I have no idea if any Camaro guys use it, but can tell you that no one I know is unhappy with them in the vette world.
"Make yourself sheep and the wolves will eat you"
LT1Zob is offline   Reply With Quote
Old 08-14-2020, 04:07 AM   #3
ariZona28
Give speed a chance
ariZona28's Avatar
That's for the feedback. Going to do a little more research then I'll have to pry open the 'ol wallet. Have plenty of these rain channels in my area, if you don't approach them correctly you can make some undesirable contact.
Old 08-16-2020, 12:16 AM   #4
LT1Zob
LT1Zob's Avatar
Very familiar with your problem sir. I have a driveway designed by an a-hole, I had to lift my vette slightly on the factory bolts to not leave my painted splitter and winglets behind.
Old 08-17-2020, 02:57 PM   #5
Rainbow1616
Rainbow1616's Avatar
Drives: 2011 Inferno Orange Camaro 2SS/RS
I don't have any physical protection but I do have a camera in front that I can pop up when I get close to anything. It has saved me more than once!
Rainbow1616 is offline   Reply With Quote
Old 08-17-2020, 03:23 PM   #6
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
You could probably bribe a few Hellcat guys for their yellow lip protectors
My VIN = 2G1FK1EJ9A9105017
Old 08-17-2020, 03:53 PM   #7
LT1Zob
LT1Zob's Avatar
The cameras are a great option, love mine too, but sadly they do nothing for the places you have to drive up or over, like your driveway or overly aggressive rain channels. So having the slipLo helps, but keep in mind, anything you add to the bottom on your splitter, you’re getting it closer to the ground. I have three layers of thick “fabric” tape. I’ve rubbed a couple times, but no damage to the splitter. Just replaced the tape. The key is going very slow. At higher speeds, the tape I have would be pretty useless.
Still, slipLo is a solution a lot of people like. Good luck OP, I know it sucks any way you slice it.
Old 08-17-2020, 03:57 PM   #8
bayarea408
bayarea408's Avatar
Drives: T
the yellow ones
bayarea408 is offline   Reply With Quote
Old 08-18-2020, 03:05 PM   #9
ADVMax
Sporting Foole
ADVMax's Avatar
Drives: 2010 Camaro SS
like
ADVMax is offline   Reply With Quote
