Old 08-16-2020, 06:09 PM   #1
TfBee757
Drives: 2015 Chevrolet Camaro 2SS
Smile Will they fit??
So I've been thinking about getting new tires/ wheels soon and I wanted to do a square setup.
Konig Ampliforms: 19x10 +28
Toyo Tires Proxes: 275/40/20
Will they work?
TfBee757 is offline   Reply With Quote
Old 08-16-2020, 06:19 PM   #2
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
are you kidding! no they won't.
19 inch rim 20 inch tire
lemontwist is offline   Reply With Quote
Old 08-16-2020, 06:22 PM   #3
TfBee757
What tire size should I go with? ����
Old 08-16-2020, 06:50 PM   #4
TfBee757
Pretty much new to fitment haha
Old 08-16-2020, 08:12 PM   #5
EMB135Driver
Jedi Master
EMB135Driver's Avatar
Drives: Boeing 757/767+2010 IBM 2SS
I’d Probably start out with 20 inch wheels if you’re getting 20 inch tires, but that’s just me
EMB135Driver is offline   Reply With Quote
Old 08-16-2020, 08:18 PM   #6
TfBee757
I meant 19" tires haha, but I'm thinking they should fit up with no extra modifications?
Old 08-16-2020, 08:39 PM   #7
EMB135Driver
Jedi Master
275/40R20 tires will fit on 19 inch wheels, but you won’t be able to inflate them and handling will be pretty bad after the first few feet you travel, like you’re running on just the rims (you will be, cause the tires will separate)
Old 08-16-2020, 08:43 PM   #8
TfBee757
I'm going to be running 275/40R19 tires, the 20" tires was a typo
Old 08-16-2020, 09:42 PM   #9
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
Unless your lowred 1" id say no , 27.66 is little small for car that made to run a 29" tire
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 08-16-2020, 10:05 PM   #10
TfBee757
Oh really? I've seen people running 19" tires/ wheels?
Old 08-17-2020, 12:28 AM   #11
davidscamaro
Rim size has nothing to do with how tall the tire is , tire size your thinking about would leave quite a bit of gap in the fender well , the 275 40 19 is over a inch shorter than a 275 40 20 ..... metric tire sizes are not like imperial sizes , tire diameter changes
Old 08-17-2020, 12:41 AM   #12
EMB135Driver
Jedi Master
I think you should run whatever size you want...
Old 08-17-2020, 04:30 AM   #13
TfBee757
I gotcha, thanks for clearing it up
Old 08-17-2020, 07:36 AM   #14
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
The offset is what is most important. I have two sets of 19" wheels, one has 1LE widths and offset with 285/35 and the other set are Z/28 wheels with 305/30.
The staggered widths require different offsets front to rear. I don't remember the offset numbers, but you can research it.
Sent from my Pixel XL using Tapatalk
fitment
