Old 08-17-2020, 09:41 PM   #1
Blownfogger540
Blownfogger540's Avatar
Drives: 2013 ZL1 416
17" 18" 19" DR'S what fits on stock rear ZL1 Suspension
what size rims and dr's will fit on the stock zl1 rear setup
Blownfogger540 is offline   Reply With Quote
Old 08-18-2020, 07:32 AM   #2
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
Wow...that's a loaded question. Read ProstockJohn's sticky on wheels and tires...it's fairly complete.
JB'sZL1 is offline   Reply With Quote
Old 08-21-2020, 10:10 PM   #3
JMI
JMI's Avatar
Drives: Red Jewel Camaro SS
I ran 17".
Tie down the hand brake cable and you may need to trim the sway bar link bolt.On a hard launch,the end of the bolt may touch the rim.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
JMI is offline   Reply With Quote
Old 08-23-2020, 06:33 PM   #4
mypurpled
mypurpled
Drives: 2014 ZL1 Camaro
Mine are RC Components 17x10 with a 325/45/17 M&H drag radial
mypurpled is offline   Reply With Quote
Old 08-23-2020, 09:34 PM   #5
Blownfogger540
thanks for the pic too
do you know what offset the rims are you used ?
Old 08-23-2020, 09:36 PM   #6
Blownfogger540
Originally Posted by JMI View Post
I ran 17".
thanks for the info
Old 08-30-2020, 10:06 AM   #7
mypurpled
mypurpled
Check their website.It works out to be around a 7.2” offset.
Old 01-01-2021, 12:06 AM   #8
Blownfogger540
what rim specs are on the front to clear the zl1 brakes
Old 01-02-2021, 10:45 AM   #9
madmikeismad
Drives: 2012 ZL1
I run race star 17's with a 315/50, with no issues.
92-705253B
'12 ZL1 - RPM 5", TSP 2" headers, Speed Engineering 3" header back, Dayco 8.66 lower/LPE 2.38 upper with solid isolator and 10 bolt hub, hand ported blower and snout and went way too far, ID1050x's, DSX aux harness with a summit 400lph pump on E, NGK TR8's with Taylor wires, 160* tstat, NW 102, UPR catch cans, HP Tuners, Stock unopened long block
madmikeismad is offline   Reply With Quote
