12-25-2009, 11:52 PM | #1 |
Drives: 10 Procharged SS Join Date: Oct 2009
Wanting to Install my ARH... any advise?
Ive never installed headers myself, but i know my way around an engine faily well. I was wanting to install my ARH (1 7/8 longtubes with high flow cats and x-pipe) this weekend and im wondering how hard it really is. Has anyone installed them themselves yet?
I have an L99 with a Corsa Cat-Back already installed. I also just installed my Pipeline Cold Air Intake today and cant wait to get the tune for everything. Anyways any tips would be very helpful? Would i have to do any cutting or welding because of my Corsa Cat-Back? (2.5 inch hook up) Thanks guys
10 Camaro: Built 376, LSA Heads, BTR valve train and Stage III Camshaft. F1A 12 Rib-3.75 pulley (17psi), Squash Dual Fuel System with Return (Dual Walbro 450LPH on a Hobbs Switch), Aeromotive regulator, Holley Fuel Rails, ID1300's. RMVB 4L80, 4K Stall, and Trans-brake. 9" IRS, 3.50 gears with a full spool
12-26-2009, 01:20 AM | #2 |
Drives: 2009 Corvette Z06 Join Date: Jun 2009
I just dropped in a pair of Stainless Works headers.. No welding.. but. you should have ramps and some jack stands.. you need about 2 ft clearance to bring the headers up through the bottom of car.. ALSO you NEEED a second person when doing this so you don't crack any spark plugs. i used rtv sealer on the gaskets ( as the directions instructed), but if i did it again.. id just buy new gaskets.
"What Do I Feel When I Kill A Terrorist? A Little Recoil" |
12-26-2009, 03:12 PM | #3 |
I would remove all spark plugs before install. besides that it should be straightforward
12-26-2009, 03:27 PM | #4 |
Thanks guys.... starting on it now. I have a shop with a lift to use so i hope its easy.
My ARH came with new manifold gaskets so i will use them. Also im gonna use some anti-seeze on my bolts. Hope it all works out. I'll come back to take a break and check this forum to see if anyone has anymore advise. Thanks again!!!
12-26-2009, 03:32 PM | #5 | |
Drives: Black 2SS Join Date: Oct 2009
Your best bet is to reuse the factory MLS gaskets (no RTV needed). The anti-seize is a must IMO when dealing with stainless and aluminum. Other than that, this car is the easiest I've ever installed headers on. |
12-27-2009, 10:08 AM | #6 | |
Drives: 2000 Silverado Join Date: Apr 2009
shoulda bolted right up!
IOM 2SSRS LS3 R6P - VIN 7553 Delivered 5/22/2009 Kooks, Corsa and Roto-Fab - SOLD 9/2010
VR 2SSRS LS3 - Borla, SLP CAI |
12-29-2009, 10:56 AM | #7 |
Can't wait to hear it, that is the same system I was thinking for my Camaro.
12-29-2009, 11:05 AM | #8 | ||
CamaroFans.com
Me Too... |
12-29-2009, 11:07 AM | #9 |
Drives: Camaro GT Join Date: Dec 2009
Yeah, Mind the Spark Plugs!!
12-29-2009, 07:21 PM | #10 | |
Yeah i realize that now... the only good thing about it is that the entire system is very loud now, which is exactly what i was looking for. I plan on putting on a Cam and i can use the resonators from my cat-back to quiet it down a bit so im not getting pulled over all the time for noise complaints (since i like to constantly give it hell). Because right now this thing is screaming!!!!! (and i love every minute of it) Thanks for rubbing it in though!! Just kidding
12-29-2009, 07:26 PM | #11 | |
I had a chance to hear and feel the difference by installing my Corsa Cat-back on first. I was a bit dissapointed with the sound, but after combining it with the ARH....... im speechless!!! I almost went with kooks (which are very good and more cost effective, but you get what you pay for) and glad that i didnt. I love these headers and they were so easy to install.
12-29-2009, 07:48 PM | #12 |
Proud IBM Owner
bws_82, good to hear all your nice comments, and I want loud also, I live in the country so no neighbors to bother, just sounds fun HUH? ARH for me then, and you said easy to install right, You didn't have to lower or move and steering linkage right?
My Baby, 1SS/RS Auto |
12-29-2009, 08:53 PM | #13 | ||
Nothing wrong with the Kooks either. Both headers are 304 stainless. I had my Kooks ceramic coated to help with the heat. Here is what the Kooks, no cats, and Borla catback sound like with a cam. |
12-29-2009, 09:39 PM | #14 | |
CamaroFans.com
I plan on leaving the Corsa resonator so it's not quite that loud... should be just right. |
Similar Threads | ||||
Complete ******** install from a Novice | Susantroy1 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 63 | 07-31-2015 01:25 PM |
DIY Hurst Short Throw Shifter Install - Pix and Video | TAG UR IT | Camaro DIY & HOW-TO instructions & discussions | 121 | 02-26-2015 10:08 AM |
ARH Long-Tubes Installed on LS3 with Factory Mufflers | ZZcamaro | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 73 | 08-31-2009 09:57 PM |
DIY : Install catback on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 3 | 08-09-2009 04:36 PM |
TSP Intake & ARH Headers Install Dyno Results | Jason 98 TA | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 8 | 08-04-2009 10:05 PM |
