Old 08-19-2020, 09:26 PM   #1
whoanelli
Drives: 2014 2LT RS
Cam1 & Pioneer AVIC 8500NEX
I'm quite pleased with the CAM1. Buttons programmed without a hitch and the fit and finish look great. The face of the head unit I chose doesn't open completely for access to the cd, it's quite a tight fit. No biggy as I don't have cds. If anyone has a similar unit and can get Apple Carplay to connect wirelessly let me know. Bluetooth works fine (iphone 10 BTW), but it won't connect via wifi once it boots up. I placed my old head unit and dash kits (2) in the for sale section of the forum.
whoanelli is offline   Reply With Quote
Old 08-20-2020, 01:03 AM   #2
bottletalk
Drives: 15 Camaro 2SS M6
is your decks firmware up to date? phone as well?
does your iPhone have restrictions on CarPlay? can you pair the phone with the deck??
bottletalk is offline   Reply With Quote
Old 08-20-2020, 05:53 AM   #3
whoanelli
Drives: 2014 2LT RS
Yes my installer installed the latest firmware. I can connect via USB and use Carplay just fine and yes bluetooth connects seamlessly. It just won't connect wirelessly for Carplay specifically. Thanks for the reply...
Old 08-20-2020, 08:21 AM   #4
VeeGeeTea
LEXi is Sassy and Classy
VeeGeeTea's Avatar
Drives: 2012 Camaro 2LT RS Boston Acoustic
I believe Apple CarPlay has country restrictions.
You may want to manually turn on CarPlay under your Apple device's Bluetooth settings.
VeeGeeTea is offline   Reply With Quote
Old 08-20-2020, 02:02 PM   #5
whoanelli
Drives: 2014 2LT RS
Got it working, thanks to all...
Old 08-20-2020, 10:51 PM   #6
bottletalk
what was it? your solution could help others using search with the same problem.
Old 08-21-2020, 08:41 AM   #7
whoanelli
Drives: 2014 2LT RS
Sure. Although I'm not positive on this, it's the only variable I can pinpoint. My installer had several Wifi sources that my phone was picking up at his shop. We think when the phone and headunit were attempting to establish a connection there could've been "interference" from these other sources? Once I got home and every time I've started the car since, wireless Carplay has connected seamlessly. I know it seems to be unlikely, but as I said, that's the only difference in the process.....
