08-20-2020, 10:30 PM | #1 |
Drives: 2010 Camaro 2SS Join Date: Jul 2020
Havoc Rear Diffuser
Hello, I just got my havoc rear diffuser in the mail and am trying to debate how to get it painted. Both pieces satin black? Inside piece satin black and outside piece black to match car? Outside piece satin black and inside piece black to match my car? I am stuck. I have looked online at a lot of pictures but they all seem to be edited. Put your havoc pictures down below. Bonus if it’s on a black car! Thanks!
08-21-2020, 07:08 AM | #2 |
Be prepared to tweak it to fit properly.
Mine is Base coat black with clear coat, my insert is the hydro dipped carbon fiber with clear coat. My thoughts are the outer bumper piece should def be gloss black, but the inner can be gloss or satin or whatever. |
08-21-2020, 08:50 AM | #3 | |
08-21-2020, 11:03 AM | #4 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
I painted the center to match the body.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ Last edited by Dizzy82; 08-23-2020 at 12:54 PM. |
08-23-2020, 10:44 AM | #5 |
Drives: 2011 Camaro SS Join Date: Sep 2017
Would like to see the center painted white on a summit white one.
2011 SS -GPI SS3 vvt, circle D 4c, 3.91 gears, solo mach xl exhaust, speed engineering headers, bo white ported throttle body, Roto fab intake, adm transcooler, elite catch can
08-23-2020, 10:51 AM | #6 |
How does it mount to the rear bumper cover? Does it use stock molded in tangs, bolt on or tape? Any modifications required of the rear bumper cover ?
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
08-23-2020, 11:44 AM | #7 |
Uses the oem clips. I believe you have to take off the bumper though and drill in some screws. I’m not entirely sure, that’s just what I’ve seen from some videos on it. I’m not actually installing. I have a zl1 bumper conversion kit, zl1 side rockers, that havoc rear diffuser, and a anvil auto rear notch spoiler all at a body shop right now here getting painted and installed. I’m excited to see it once I get it back!
08-23-2020, 01:02 PM | #8 |
08-23-2020, 08:39 PM | #9 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
My center section and bumper cover are both gloss black to match factory paint. I plasti-dipped the center section a matte dark grey for contrast.
08-24-2020, 08:12 PM | #10 |
11-06-2020, 10:54 PM | #11 | |
Drives: 2011 camaro 2LT Join Date: Nov 2012
