![]() Drives: NASA SPEC IRON MUSTANG, 2023 ZL1 Join Date: Jan 2016
CHEVROLET TRACK ALIGNMENT PDF?
Does anyone have a pdf copy of the original track alignment tips/suggestions/settings for the 13-15 1LE? I saved one for the Z/28 but I haven't seen one for the 1LE. Looking for alignment settings for an unmodified car with stock Goodyears. Thanks in advance.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
Are you talking about the old Pedders info? I think I have that somewhere.
Sent from my SM-T837V using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
![]() Drives: 2011 Camaro 2LT Join Date: Oct 2018
The link to the GM specs is now defunct. Here’s the pedders and pfadt track specs:
https://www.camaro5.com/forums/attac...8&d=1410280290 And here’s the GM text for the Z28: 3. ADJUST THE FOUR CORNERS TIRE AND WHEEL ALIGNMENT (OWNER’S MANUAL: 9-10) The summer-only tires on Camaro Z/28 require inflation and pressure adjustment when driving at high speeds on a track (where legal). • Limit the vehicle load to the driver only with no other cargo and inflate the tires to at least 26 psi (180 kPa) Camaro Z/28 wheel alignment settings can be set as follows for increased handling and performance: FRONT • Remove the spring spacers from the front suspension and place them in the glove box. If the car is to be on a trailer for any reason, the spacers need to be placed back in the front springs to obtain ground clearance • Caster: 5.9 +/- 0.50 degrees • Camber: -1.5 +/- 0.50 degrees • Total or Sum Toe: 0.1 +/- 0.20 degrees REAR • Camber: -1 +/- 0.50 degrees • Total or Sum Toe: 0.1 +/- 0.20 degrees • Thrust Angle: 0 +/- 0.20 degrees |
Thank you
![]() Drives: 2014 Camaro SS 1LE Join Date: Aug 2020
Do you guys have any experience or feedback using peddlers specs for the track ? I've got a 14 1LE that I plan taking on to the track next month and I just ordered tires and want to get it aligned. Suspension is stock. Is -1.5 neg front camber about the max you can get or is that the desired amount ? Thanks
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro 1LE Join Date: Jul 2012
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
So for us old guys that don't track the car and only run on the street , what the best overall alignment specs for good tire wear ?
OLD GUY FLYING FAST AND LOW
#8 | |
#9 |
Thanks for the input. So are you running - .75 camber for the rear and .1 toe in on all 4 corners ?
#10 |
If I recall front camber of -1 to -1.25 would be a good target for improved handling on the street without being overly aggressive on tire wear. Rear camber rule of thumb is half of the front camber. So rear camber would be around -.5. Rear toe I believe was recommended to be .12 toe IN each side for a total of .24 toe IN. Front toe should be set at 0 each side for the street. Toe in or out on the front on the street will probably wear your tires faster than the camber will. So for tire wear the Toe is probably most critical on the street.
#11 | |
![]() Sent from my SM-T837V using Tapatalk
#12 |
![]() Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
Here's the factory 1LE alignment settings. When I did some suspension upgrades, I had my local shop aligned to this. It came from a previous Camaro5 thread on alignment. My tread wear is very even.
![]() Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
