Old 08-22-2020, 05:33 PM   #1
ChevySS10
Drives: 2010 Camaro SS
Angry low oil pressure
Hey guys, i see tons of posts on low oil pressure... well... its happened to me now... and ive replaced the sending unit, and oil pump. it is now a melling 10295. with the red spring inside which is high pressure... at idle when its warm im at 15 psi. driving is around 30 psi. it is a cammed v8 6.2, tsp stage 3 cam, stock bottom end. top is basically done. and has a holley sniper low pro intake 102mm tb. and... im at a loss. my tune/mechanic suggests the relief spring/valve is stuck... so i tapped on the timing cover with a hammer today while i did the oil change... im just lost... ran out of things to check i guess? short of tearing into the front of the motor....pickup tube loose? maybe? i dunno...
ChevySS10 is offline   Reply With Quote
Old 08-22-2020, 05:35 PM   #2
ChevySS10
Angry low engine oil, stop engine
forgot to mention i get the dic warning... low engine oil stop engine randomly... at idle... usually in a drive through, and only when ive used the a/c or heater.... only 2 times its popped up..
Old 08-22-2020, 06:39 PM   #3
hammdo
'It's an experiment'
hammdo's Avatar
O-ring could be cut at the pump — very common when doing new pump...
I used Driven’s assembly lube instead of oil to avoid cuts in the o-ring...
-Don
747 RWHP 794 RWTQ
