![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '20 ZLE Join Date: Jun 2020
SD Card for PDR
Question: Please tell GM to start providing a formatted SD card with each car with a PDR. I've wasted hours formatting cards in different ways incl. FAT32 but the car still does not see the card. Thanks
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#2 | |
![]() Drives: '16 Z06 7 Spd, 2024 High Country HD Join Date: May 2015
Are you getting any messages from PDR? Last edited by h422694; 08-23-2020 at 09:27 AM. |
Yes, it says SD card not inserted.
I've tried two different cards in FAT32 and another format. Can the USB port be used for an SD card? I have a nice USB SD card read writer
2020 ZL1LE A10.
#4 | |
I saw a ;ot of similar issues on another forum and most were resolved by correct formatting and using a Class 10 card. Also USB drive will not get recognized for PDR. |
![]() Drives: 2018 1SS 1LE Join Date: Jul 2020
2018 1SS 1LE Hyper Blue
#6 |
I've been trying the SD reader in the console because the one you refer to is broken or something and I had to use pliers to get the card adapter out
2020 ZL1LE A10.
#7 | |
You are saying once installed, when you push it in it doesn't pop back out? Might have a bent pin in the socket which could cause it both not to work and not to pop out. I have never seen anything that would indicate you can use anything but that socket for the PDR SD Card.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
The centre console SD slot is for the Navigation SD(if you have navigation) or media storage(if you don't have navigation and swap the centre console one out with an adapter with SD slot).
As mentioned, the PDR slot is above the OBD2 port.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
#9 | |
The way these SD card readers work is you insert the SD card and push in until it locks. To remove it, you push it in and it will release and come back out enough that you can easily pull it. If you originally used a microSD with adapter and the adapter is still in reader, I would carefully press it in like you were originally putting it in and that should release it if it's not damaged. Good Luck. |
#10 |
My car is on the way to HPE for additional mods so I can't try that port again for a few weeks
2020 ZL1LE A10.
