Old 08-24-2020, 12:11 AM   #1
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
MAF wiring schematic
Taken from the 2014 Service Manual
For those that might need it
Name:  MAF Schematic.jpg
FasNuf is offline   Reply With Quote
Old 08-24-2020, 02:10 AM   #2
'10CamaroDude
Drives: 2010 Camaro LS
Yeah, but that does not tell you what each circuit in the MAF is.
L99/LS3:
Pin - Wire - Circuit- Function
A - 0.5 - YE - 492 -MAF Sensor Signal
B - 0.5 - BK/WH - 451- Ground
C - 0.5 - PK - 239- Ignition Voltage
D - 0.5 - TN - 2760 - Low Reference
E - 0.5 - L-BU - 6289 - Intake Air Temperature Sensor Signal
LLT ENGINE:
Pin Wire Circuit Function
1 0.5 TN 2760 Low Reference
2 0.5 BK/WH 451 Ground
3 0.5 L-BU 6289 Intake Air Temperature Sensor Signal
4 0.5 PK 239 Ignition Voltage
5 0.5 YE 492 MAF Sensor Signal
'10CamaroDude is offline   Reply With Quote
Old 08-24-2020, 02:23 AM   #3
FasNuf
FasNuf's Avatar
Thanks for the addition, I had a request for the page so this was a way to post it for him.
Old 08-24-2020, 02:34 PM   #4
FasNuf
FasNuf's Avatar
L99/LS3:
LLT ENGINE:
I don't have a schematic for the LLT since it's older and my manual only shows the LFX. Feel free to post a schematic for yout LLT specs, Thanks
Old 08-24-2020, 03:36 PM   #5
FasNuf
FasNuf's Avatar
Oh and just so there's no confusion...
Old 08-24-2020, 03:52 PM   #6
'10CamaroDude
https://kvisit.com/Qg/1K0B
All of engine performance diagrams 1-6, MAF is on Page 5.
Old 07-12-2023, 02:21 PM   #7
rsrsrs
rsrsrs's Avatar
Drives: '11 2SS/RS M6
There has to be some sort of typo because there is no Circuit 239 for Ignition Voltage, only 439 which is pin 19 on the PCM.
And yes I resurrected a 3 year old thread because I'm having issues with my car and trying to confirm I'm not crazy and 439 is indeed correct.
rsrsrs is offline   Reply With Quote
Old 07-12-2023, 02:27 PM   #8
gtstorey
So which motor are you working on?
gtstorey is online now   Reply With Quote
