Old 08-26-2020, 03:27 PM   #1
ReVeNanTSS
Drives: 2012 Camaro SS 45th Anniversary EU
Arrow Only resonator - Straight pipe. Choose H location guys
Hi Guys,
Today I delete resonator. Made 2 independent straight pipes. I want get some old school muscle sound. Without resonator it is better sounding. I like it. But for future I want connect this pipes with same diameter pipe and make H pipe (After convertors where resonator begins). To get more old muscle sound on idle and make a little bit back pressure. Because I noticed I lose some torque in 2K-2.5K RPM range. Can you describe where to put H connection and make some little back pressure for not losing power. Please look for photo below I marked location for connection of H pipe. Choose which one is better for better sound and little backpressure: Engine: L99, AFM:disabled
ReVeNanTSS is offline   Reply With Quote
Old 08-26-2020, 03:39 PM   #2
NEstyle
Drives: Caprice
H-pipes don't add backpressure and you don't want backpressure. Now that that's out of the way, it will be pretty much impossible for anyone to tell you where an H-pipe will work best without testing each position on a dyno.
NEstyle is offline   Reply With Quote
Old 08-26-2020, 03:40 PM   #3
ReVeNanTSS
I prefer 1 because on LS3 stock H connection is there
Old 08-26-2020, 03:42 PM   #4
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
Wouldn't it be easier to get a used LS3 exhaust?
George-CZ is offline   Reply With Quote
Old 08-26-2020, 03:43 PM   #5
ReVeNanTSS
Not in my country
We don't have LS3 camaros here..
Old 08-26-2020, 03:55 PM   #6
George-CZ
George-CZ's Avatar
Otherwise I also like the old school sound H-pipe.
After all, that's why I didn't buy any performance exhaust system. All I found was an X-pipe and I just didn't like the sound.
I have a vision in my head to once buy a 3 "SW retro chambered, throw out an X-pipe and replace it with an H-pipe. The sound must be awsome !!!
Old 08-26-2020, 03:59 PM   #7
George-CZ
George-CZ's Avatar
Originally Posted by ReVeNanTSS View Post
Not in my country
I understand Azerbaijan ... I can see it now.
Old 08-26-2020, 04:12 PM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Judging from all the catback systems I have seen in my time for these Camaros, and mine is an L99 all cammed up, the x will give you more flow and it also will create a raspy sound and sound weird, mine was lije that before the cam. The h will give you a more lower growlier sound for sure but no added flow. The location I put my x in is at location# 2 where the indention is in that big resonator, also the systems that have an h instead like the LS3 the h is also located there, just in front of the trans tunnel cross brace. If you cut open that big resonator you will see that that area has an h cross over to the other side, and the LS3 as well where their resonators are as well. Hope this helps and good luck sir.
Old 08-26-2020, 04:25 PM   #9
ReVeNanTSS
Yeah i see inside of resonator on location 2 has area. In front of cross brace to engine yes?
Old 08-26-2020, 04:29 PM   #10
NEstyle
Drives: Caprice
I'm not saying don't install one. I'm just saying that they don't add backpressure. I have an H and recommend them over X's because X's sound horrible in my (and many others) opinion.
Old 08-26-2020, 04:30 PM   #11
ReVeNanTSS
Yes that is why i wat H pipe)
Old 08-27-2020, 09:43 AM   #12
byrds8
byrds8's Avatar
Drives: 2013 Camaro 2SS, L99
I have never heard anyone say my car sounded bad and it has an x-pipe on it. Most people say it sounds pretty awesome. I have the below SOLO Performance on it along with LTs.
https://shop-solo-performance.com/en...0-present.html
2013 Camaro SS/RS, Stainless Power long tube headers with HF's, Air Raid CAI, Solo Mach XL cat back, BC Racing coil overs, Elite Engineering catch can, Ferrada Forge 8 Wheels, Windows tinted at 20%, Tuned by Dyno Steve.
byrds8 is offline   Reply With Quote
Old 08-27-2020, 11:51 AM   #13
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Trans tunnel cross brace is where you want to install the h-pipe. Black cross bar in this pic.
Old 08-27-2020, 12:51 PM   #14
NEstyle
Drives: Caprice
Attachment 1042663
How did you determine that's the optimal position? Did you try multiple locations and dyno test each one and optimize the tune for each position?
exhaust, h pipe, resonator delete
