Old 09-01-2020, 01:48 PM   #1
War_Eagle
2010 RS
War_Eagle's Avatar
Drives: 2010 v6
About to try to replace my ac compressor. Anybody got a nice DIY or any tips
It s 2011 V6
War_Eagle is offline   Reply With Quote
Old 09-02-2020, 09:11 AM   #2
SS_CTS-V
Drives: 2015 SS, 2006 CTS-V (wrecked...)
Due to compressor complete failure? There could be debris in the AC lines and especially in the condenser. You can run denatured alcohol through the lines to flush the junk out, but there's still some risk.
Best practice to replace the dryer while in there. You'll need a vacuum pump to check for leaks and purge the system before adding new oil and coolant. Be sure you have the right type and amount of compressor oil. Do you have AC gauges?
SS_CTS-V is offline   Reply With Quote
Old 09-02-2020, 10:02 AM   #3
Vegas Bound
Drives: 2013 Sparkly Red One
This ^^^^
Vegas Bound is offline   Reply With Quote
Old 09-02-2020, 12:11 PM   #4
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Don't over tighten the mounting bolts or the housing will separate and all your refrigerant will escape. Don't ask me how I know.
