Old 09-04-2020, 10:47 AM   #1
Greencamaro1234
Drives: 2011 Camaro LS
Headers
I put shorty headers on my car 3 years ago,they have no coating on them,and starting to rust a little,so what’s the best way to cover them or tape them or paint them,thanks.
Greencamaro1234 is offline   Reply With Quote
Old 09-04-2020, 11:04 AM   #2
xstuntman
Drives: 2012 Victory Red LFX
Me, I'd pull them off, remove the rust, then use high temp paint.
I've also removed rust with soaking the part in vinegar so maybe keeping them wrapped in soaked paper towels might work too. Depends on how much rust you've got.
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
xstuntman is offline   Reply With Quote
Old 09-04-2020, 11:06 AM   #3
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Since they are in non coated I wouldn’t wrap them. Remove them sand away the rust and paint them with ceramic header pint.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 09-04-2020, 04:59 PM   #4
Greencamaro1234
Thanks, would be much easier to spray them for sure,and just never was confident spraying even hi temp paint on them and not stinking or burning off the paint,any particular paint,or just any from Lowe’s.
Old 09-04-2020, 05:01 PM   #5
Greencamaro1234
And actually there not even rusting after further inspection,but would definitely still sand them for proper bonding with new paint.
Old 09-04-2020, 07:29 PM   #6
xstuntman
I've used both Rust-Oleum and VHT.
Both seem about the same and worked well.
