![]() Drives: Chevy Camaro 2015 2SS RS Join Date: Feb 2020
tightening air deflectors under the bumper?
Hi, today I realized that the rubber part (air deflector) at the bottom of the front bumper Is kind of loose.
What can I do to tighten them before they fall off loose? Any help will be appreciated |
If you are referring to the rubber piece that is up under the front bumper, just take it off, I did a long time ago as it looked kinda tacky. It doesn't go much. After a while of pulling up over parking blocks you will mess it up anyway. I see a lot of cars driving around with them just hanging there "flappin" in the wind. lol
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
The air deflector does just that. It deflects air AND DIRT down and away from your engine
compartment. I replaced mine a few years ago. I also replaced the special retainer clips which were expensive as I remember.
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Don't waste your money on the GM fasteners. Go to Lowes or Home Depot and get some nylon screws and wingnuts. 1/10 the price.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
Just take it off, it's pretty useless.
As for tightening them, it's just a plastic screw and nut. They are designed to come loose and fall off in case you run over something instead ripping off your front bumper. For replacements here is the cheapest place you'll find them. Screws: https://www.clipsandfasteners.com/GM...0-p/a21301.htm nuts: https://www.clipsandfasteners.com/GM...0-p/a21302.htm |
| Tags |
| bolt, deflectors, front bumper, loose, rubber |
