Old 12-27-2009, 01:09 PM   #1
Unique Auto Depot
Drives: Camaro 2010
Noise From Center Console area (Transmission)?
Anyone getting a weird noise from the Center Console area on a M6 after 2000 rpms almost sound like a Static sound kinda
Unique Auto Depot is offline   Reply With Quote
Old 12-27-2009, 01:15 PM   #2
ffrcobra_65
could be this.
http://www.camaro5.com/forums/showthread.php?t=58090
Old 12-27-2009, 01:20 PM   #3
Unique Auto Depot
Drives: Camaro 2010
No mine does not click like that that's for sure it almost sound like static from the radio but I turned that off and it is coming from the console once I press on the clutch it stops
Old 12-27-2009, 02:02 PM   #4
ffrcobra_65
does it do it when car is not moving? If it does, you can rule out the heat shields or the tranny shifter dust boot, and the tranny.
Old 12-27-2009, 02:32 PM   #5
Unique Auto Depot
Drives: Camaro 2010
only if I Rev it up real High
Old 12-27-2009, 02:46 PM   #6
jacques
Drives: Summit White 2SS RS
YES. Exactly what I have had from day one. I can also make it happen at a stand still by revving over 2K ROM.
I got it up on the lift today and looked around. I couldn't see anything out of place or unusual. I did reposition a wire bundle on the passenger side of the car near the tranny that was touching the heat shield. Maybe that was the cause of the noise. I will let you know if the noise went away after I drive it for a few days.
jacques is offline   Reply With Quote
Old 12-27-2009, 03:03 PM   #7
Unique Auto Depot
Drives: Camaro 2010
Let me know Thanks Dealer claims they can't hear it UNREAL !!!
Old 12-27-2009, 05:58 PM   #8
Unique Auto Depot
Drives: Camaro 2010
I'm gonna take it to the dealer to have this done looks like this might be the problem
http://www.camaro5.com/forums/showthread.php?t=46740
Old 12-29-2009, 08:24 PM   #9
flyby
Drives: 2010 Silver SS
Yeah, you should take it to the dealer. If the sound is like a static sort of noise it could be the clutch disc. Whatever it is it is NOT normal.
flyby is offline   Reply With Quote
Center console different with gauge pack vs. no gauge pack? CasopoliS Cosmetics and Lighting Modification Discussions 28 10-13-2010 11:14 AM
Center console gauges? Blade Cosmetics and Lighting Modification Discussions 2 12-09-2009 04:00 PM
noise from under center shifter? francone13 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 07-24-2009 01:35 PM
noise from under center console/shifter francone13 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 07-03-2009 11:45 AM
