Old 12-27-2009, 01:59 PM   #1
billyspeed
BILLYSPEED
billyspeed's Avatar
Drives: 2016 black camaro SS
IF YOUR ON THE FENCE ABOUT THE BARTON SHORT THROW SHIFTER....
I got mine under the tree and just spent an hour putting it in.
it looks amazing
it was very simple to install with basic tools
after driving car for about an hour im still giggling !!
in my opinion it is way better then stock and priced great.
i highly recomend this shifter. its a blast !!!!
i just wish i could use both shifters at once (i ordered both styles) !! ha ha
billyspeed is offline   Reply With Quote
Old 12-27-2009, 02:15 PM   #2
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
have you experienced any rattling, shaking, vibration, sounds, etc from it? Hard acceleration and under normal load?
Old 12-27-2009, 02:43 PM   #3
billyspeed
BILLYSPEED
billyspeed's Avatar
not yet... but its only been hours.
i did read in other posts about noises.
one guy recommended macking sure the jam nut was tight.
so when i installed mine i kept that in mind.
but i will post if i do here any later......
i would recommend making sure the dust boot underneath is on correctly, that would let some noises in..
Old 12-27-2009, 02:54 PM   #4
Strokedhog
Strokedhog's Avatar
Drives: 2010 2SS M6 Black
cool just ordered mine today cant wait even though the cars in storage
Strokedhog is offline   Reply With Quote
Old 12-27-2009, 05:30 PM   #5
MikeBing
MikeBing's Avatar
Drives: 2010 CGM/IO 2SS RS
I'm glad to hear it, I'm kinda leaning toward Barton
MikeBing is offline   Reply With Quote
Old 12-28-2009, 07:40 PM   #6
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
ordered mine and should get it any day. I heard bad things about hurst.
SSTony is offline   Reply With Quote
Old 12-28-2009, 11:12 PM   #7
rauhaus camaro
SoCal C5 Family Member
rauhaus camaro's Avatar
Drives: 2010 Black Camaro 2SS with LS3
You won't be dissapointed. It is an excellent piece of CnC work. I love my Barton Shifter. I keep switching off between using the black retro billet cue ball and the pistol grip shifter. I had experienced a slight harmonic when I first installed it - then found that I did not fully tighten the 1 inch jam nut to the stick. That fixed it!!! No Vibration or harmonics whatsoever! Dave at Barton also provides very good customer service. Great product. Great Company. Can't say enough good things about Barton Industries.
rauhaus camaro is offline   Reply With Quote
Old 12-28-2009, 11:19 PM   #8
darenf02
darenf02's Avatar
Drives: 2010 Camaro 2SS/RS 6SP LS7 swapped
Now THAT is a beautiful picture......wonder if Hurst is listening to the complaints about the noise??? Found one for sale on here with only 75 miles put on it.....for that kind of money and the Hurst name, I am speechless. Still undecided about which one though........
it looks amazing
LS7 swap stage 3 cam, MSD intake, NW 103 TB, LME heads, JBA ceramic coated LT's 1 7/8" Flowmaster 3" w/high flow cats & X pipe, MPD Motorsports cowl induction hood, CAI, ZL1 front clip, Jet Mass-Air Sensor, rear valence, Stealth bulbs, 20% tint, taillight blackouts, side marker blackouts, modern SS emblem back, 427 rear emblem, S.S. rear spoiler, MGW shifter, black ZL1 replica wheels (wider), 160* thermostat, front firing 2x12" Rockford Fosgate subs, NA 619rwhp on Mustang Dyno
darenf02 is offline   Reply With Quote
Old 12-29-2009, 05:59 PM   #9
billyspeed
BILLYSPEED
billyspeed's Avatar
i did play around today on a remote road... i only heard some light noise under hard... very hard takeoffs... (dam this car is fast !!!!!) it was a kinda mechanical buzz ?? i really dont no how to explain. but i didnt hear it under normal driving. it really was no big deal in my opinion. it was nothing that made me think anything was wrong. and i still think that the short throw makes shifting way better and loads more fun....
Old 12-29-2009, 06:38 PM   #10
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Get off the fence It performs, It's priced right, you can install yourself, and it will look damn good in your Camaro !
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 12-29-2009, 10:00 PM   #11
CBH
VETT 4 5
CBH's Avatar
Drives: Yellow 1SS/RS w/ Clutch
Is that a pink knob ?
Anybody think about replacing the plastic shifter boot while it was apart ?
CBH is offline   Reply With Quote
Old 12-29-2009, 10:32 PM   #12
AZ5G
AZ5G
AZ5G's Avatar
Drives: 2010 Transformer Ed. 1SS M6
Finally had the time to install my Barton. Went with the SS knob. I cheated and had my daughter get that damn boot back on...Couldnt seem to get both my paws in there together. Anyway, no noises or rattles of any kind. And the shift gate is extremely tight. It also has a very mechanical feel. Never tried the Hurst, but am quite pleased with this unit...AZ5G
AZ5G is offline   Reply With Quote
Old 12-29-2009, 10:32 PM   #13
SSTony
SSTony's Avatar
Drives: SS Camaro
mine vibrates a lot. I did it step by step. Not sure what else to check.
Old 12-29-2009, 11:27 PM   #14
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
sstony check the rubber boot on bottom my not be on well at all could cause a bad vibrqation
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
STATUS OF A POSSIBLE RERUN TO HURST FOR SHORT THROW SHIFTER INSTALL als 011 z28 USA - California 7 12-04-2009 11:48 AM
Short Throw Hurst Shifter Not Available Matster 5th Gen Camaro SS LS LT General Discussions 51 11-09-2009 10:03 AM
Short Throw Shifter Constrained?? josh1147 Camaro Price | Ordering | Tracking | Dealers Discussions 75 02-19-2009 12:51 PM
Throw Shifter wlvrine 5th Gen Camaro SS LS LT General Discussions 8 10-24-2008 06:22 AM
