Old 09-20-2020, 11:36 AM   #1
AG1LE
AG1LE's Avatar
Drives: '14 1LE
Closed
Closed
AG1LE is offline   Reply With Quote
Old 09-20-2020, 01:51 PM   #2
HoodCheck
HoodCheck's Avatar
Drives: 2018 ZLE (M6/hyper blue)
https://www.hawksmotorsports.com/201...sv-dampers-gm/
HoodCheck is offline   Reply With Quote
Old 09-20-2020, 02:25 PM   #3
AG1LE
AG1LE's Avatar
Drives: '14 1LE
Originally Posted by HoodCheck View Post
I'm aware of this kit, but don't need the other suspension parts and don't want to spend that much.
Old 09-20-2020, 04:38 PM   #4
SIM GhostrdrZ
SIM GhostrdrZ's Avatar
Drives: ‘14 ZL1 M6 vert
Have you looked at dealers or gm parts outlet? Are they discontinued? So how much are you thinking to spend on complete dssv set up?
SIM GhostrdrZ is offline   Reply With Quote
Old 09-20-2020, 05:05 PM   #5
AG1LE
AG1LE's Avatar
Drives: '14 1LE
Yes, I can find them on the GM parts websites, but would prefer not to piece together all of the parts (plus, they are $$). It would be ideal to find a lightly used set already complete with all parts.
Old 09-20-2020, 05:40 PM   #6
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
If you can find the fronts I may know of a rear set complete and ready to bolt in. 8k miles. What do you want to spend?
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter, SS brake lines ZLI calipers, rotors/pads BMR Trailing & Toe Arms, rear cradle/diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers, HF cats, GMPP axle back, Elite Eng Catch Can, Black ZL1 20x10 & 2011 whls 285/35/20 & 305/35/20 General G-Max RS, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console, hand brake lever, Grant steering whl.
flht99b is offline   Reply With Quote
Old 09-25-2020, 04:11 PM   #7
jcole
jcole's Avatar
Drives: 2015 Z28
I have the rear but no fronts
Here we go!!!
jcole is offline   Reply With Quote
Old 10-14-2020, 03:16 PM   #8
AG1LE
AG1LE's Avatar
Drives: '14 1LE
Old 10-15-2020, 11:54 PM   #9
1970judge
Drives: 2015 Z/28, 2007 HHR
Hope that helps.
1970judge is offline   Reply With Quote
Old 10-16-2020, 09:11 AM   #10
Fast.Freddie
2015 Z/28 #48
Drives: 2015 Z/28 #48
They pop up on eBay often. There is a right on there now. Didn’t check to see if he had the other side.. Good luck!
https://www.ebay.com/itm/312815596872
Fast.Freddie is offline   Reply With Quote
Old 10-22-2020, 03:26 PM   #11
White_Camaro
White_Camaro's Avatar
Drives: 427 SS & ZLE
Somebody has a set for sale for 500$. How much do they usually go for?
White_Camaro is offline   Reply With Quote
Old 10-22-2020, 03:29 PM   #12
AG1LE
AG1LE's Avatar
Drives: '14 1LE
Yep, I'm in touch with him - hoping he decides to ship.
Old 10-22-2020, 03:34 PM   #13
SIM GhostrdrZ
New strut/shock only from gmoutlet(each) is $800 ish front, $500 ish rear. Don’t try to get them from summit or such or else or they’ll sell you non dssv. Used is whatever someone is willing to sell for. The dssv is supposedly a long life non o ring set up, so used should work well for most. Multimatic says they are long life strut/shocks because of the internal fluid flow design.
Old 10-23-2020, 07:02 AM   #14
AG1LE
AG1LE's Avatar
Drives: '14 1LE
Still looking
