Old 09-21-2020, 03:48 PM   #1
KEN CROCIE
Drives: CAMARO 2SS 2015 convert.
Stearing pull
I have a persistant pull to the left. Alignment checked 4 times , front tires swapped left to right - twice. I'm thinking it's not alignment. Ideas please. no crash history.
2015 convert.
KEN CROCIE is offline   Reply With Quote
Old 09-21-2020, 04:19 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
Can you post your alignment specs? Even side to side? Neutral thrust angle?
KillboyPowerhead is offline   Reply With Quote
Old 09-23-2020, 12:42 AM   #3
Plastik
Plastik's Avatar
Drives: 2011 Camaro 2ss Convertible
2015 convert.
I have the same issue with my 11 vert. Same after new tires brakes and alignment. Didnt get the alignment data. It's like a tire pull but not severe. Depends what kind of road I'm on. No accidents or suspension work.
Plastik is offline   Reply With Quote
Old 09-23-2020, 07:44 PM   #4
Cristjw
Cristjw's Avatar
Drives: 2014 Camaro RS 2LT convertible
I always felt like when the pulling changes based on the road then the alignment is spot on and now you are at the mercy of the crown in the road. I sense this on a fresh tire rotation for example. Just a feeling.
Cristjw is offline   Reply With Quote
Old 09-24-2020, 12:05 AM   #5
Plastik
Plastik's Avatar
Gonna replace the fronts. Got 30 K on them and its time. When I do I'm going for a 2 wheel alignment. Noticed today that it felt like a flat spot on the drivers side. Might be a bad belt or weak spot. We'll see what it does afterward.
Old 09-25-2020, 12:36 PM   #6
KEN CROCIE
alignment specs
LF cam -0.9deg............... RF cam -0.8 deg
cas 6.9 deg....................... cas 7.4 deg
toe 0.07 deg..................... toe 0.08 deg
LR cam -0.4 deg.................. RR cam -0.5 deg
toe 0.06 deg....................... toe 0.10 deg
thrust angle -0.02 deg.
