09-21-2020, 05:43 PM | #1 |
Drives: 2018 NFG 2SS 1LE! Join Date: Jul 2018
Track Day wear and tear questions...
So can some of you more experienced guys share things that will start to wear as the track days start to add up on these cars? Tires and brakes are obvious but how about items like wheel bearings, hubs, sway bar endlinks or maybe bushings? Just wondering what to expect. I swear I already have a wheel bearing making noise on slow turns but it could be a brake pad just touching or something.
09-21-2020, 06:27 PM | #2 |
Drives: ZL1 1LE Join Date: Jul 2020
All of the items mentioned above are going to wear at an accelerated rate. If the car's still under warranty though and stock, I hear they'll replace these items under warranty. Haven't tested this out myself, but I'm assuming if I keep tracking my car I'll find out first hand.
09-21-2020, 07:01 PM | #3 |
44 track days so far and no issues except consumables (knocking on wood) including rotors
09-21-2020, 07:07 PM | #4 |
09-21-2020, 07:20 PM | #5 |
Drives: 2018 ZL1 1LE Join Date: May 2019
Ive had my entire water pump housing and pump replaced due to a weeping seal under warranty the day after a sebring event.
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial Will buy your GoodYear Supercar 3R Take offs! |
09-21-2020, 08:17 PM | #6 |
Drives: 2020 ZLE Rally Green A10 Join Date: Sep 2016
09-21-2020, 08:30 PM | #7 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
NPP, MRC, Tinted side & rear reflectors, OEM ZL1 Rockers / 3rd Brake / Darken tail lights, OEM Blk rear splash guards, Satin hood wrap, Fuse pull, Sound tube delete, Cat delete, Ported 95 TB, Ported MSD IM, Dry RotoFab, ARH 1 7/8 headers, E85, "Performance Dyno" Tune, BMR "pieces", "Track" alignment, Hawk DCT-70/70's w/SRF, Goodridge lines, Ti shims, Red powdered calipers, 18" APEX SM-10's w/ Pirelli DH's, FE4 Vert swaybars, Brake cooling ducts, ATI 10% UD, Vorshlag camber plates, OEM 1LE Splitter w/APR Ext., Velossa BIG MOUTH Ram Air, CF QA1, ZLE brakes(F)
09-21-2020, 09:45 PM | #8 |
09-22-2020, 04:21 AM | #9 |
Drives: 2017 SS 1LE Join Date: Mar 2017
23 events. Had to replace my key fob.... (Plus fluids, 3 sets of tires, pads, front rotors, and a few bad habits!)
09-22-2020, 08:47 AM | #10 |
Drives: 1LE Join Date: Sep 2017
09-22-2020, 08:52 AM | #11 |
You dont want to hear my list of parts if it going to make you shy away from tracking that is for dam sure!
I pretty much have broken everything, thats why they call me BAM BAM |
09-22-2020, 09:12 AM | #12 |
Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
What FL tracks do you frequent?
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
09-22-2020, 10:09 AM | #13 |
Drives: 2017 SS 1LE Join Date: Jan 2018
I had rear wheel bearings replaced at 36k, front balljoints at 43k, getting tie rods replaced soon but only because they're seized and they can't adjust them, not worn out. Oh yeah oil pan gasket had a very small drip at 41k and that was covered as well. Car sees quite a bit of track and autocross use as well as being beat on through Vermont winters. Factory warranty, cpo extended warranty, and GM extended warranty have all had no issues. And I usually bring it in with stickers and numbers from the track still on it. Overall very happy with it and for how I use it honestly surprised more stuff hasn't worn out.
09-22-2020, 11:04 AM | #14 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
PS Keep pushing man and pats to Fozzie pls |
