![]() Drives: 2011 Camaro 2LT Join Date: Oct 2018
Back from the Dyno
I just returned from Arizona Extreme Motorsports here in PHX. My 2011 RS with Overkill SC and Alky meth kit hit 412 RWHP on a hot desert day. The dips on the dyno sheet are from traction control (!!!). Otherwise, nice smooth power building all the way up to the redline. Car hauls some serious ass now.
![]() Drives: 2014 Camaro Join Date: Feb 2020
Did you get an AFR RPM plot as well? I hate when dynos use MPH instead of RPM
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Nice numbers.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
No AFR/RPM plot, but AFRs under full boost are consistently in the high 11s until redline. Best 0-60 time so far (as calculates by my P3 gauge):
For the record, those aren’t white Crocks. They’re special edition Jason Halloween racing shoes.
| Tags |
| dyno, supercharged horse power |
