Old 09-24-2020, 10:47 PM   #1
Leo72793
Drives: 2011 2SS/RS
Drivetrain click/pop
Are the 5th gens known for noisy driveshafts? When i am in park and shift to reverse or drive, it makes a decently loud click/pop. no metter how hard the brakes are applied. just happens. guess my music was always on so i never heard it. Just wondering
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers w/ Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle
•Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp
Leo72793 is offline   Reply With Quote
Old 09-24-2020, 11:00 PM   #2
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
there was a tsb on the thrust washers for the rear cv axles
Sent from my SM-G975U using Tapatalk
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 09-24-2020, 11:04 PM   #3
Roader
Drives: Camaro
Mine has done it for so long I just got use to it. Couldn’t track it down no matter what I did
Roader is offline   Reply With Quote
Old 09-25-2020, 08:56 AM   #4
Avenging Orange
Avenging Orange's Avatar
We have a 2-piece driveshaft.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 09-25-2020, 11:27 AM   #5
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
drivetrain slop between the trans and tires, won't matter how hard the brakes are pressed. Some slop is normal, I don't have an auto do I am not sure how normal the noise is but typically there will be some noise going from reverse to drive and back.
Greenhornet2 is offline   Reply With Quote
Old 09-25-2020, 07:05 PM   #6
Roader
Drives: Camaro
I already replaced it with a one piece
Old 09-25-2020, 10:29 PM   #7
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Could be thrust washers or pinion bearing play.
More to come.
Black_SS10 is offline   Reply With Quote
