![]() ![]() ![]() ![]() Drives: 2012 Victory Red LFX Join Date: Dec 2012
What gears?
So after doing some research (what i could find) it looks like i can swap my LS2 automatics 2.92 gears by going with an LT carrier and installing a 3.55 set.
Is there anyone making a 3.73 or 3.91 set for the LT automatic carrier? Really, really want 3.91s.
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
![]() Drives: 2011 Camaro 2LT Join Date: Oct 2018
I don’t believe so. Isn’t Richmond the only company making 3.55s? I’ve seen a lot of complaints that those gears make a lot of noise. I don’t have the LS2 (RS that had 3.27s) but swapped in a 3.91 carriers, axles, and hubs from a 1LE. Absolutely love it and wouldn’t go back. Even with the supercharger that I just added.
Ive heard they were noisy but never any updates on if they grew quieter once they wore in.
My goal of running 3.91s might be dying.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
I had both 3.73 and 3.91 in my 2012. The 3.91 felt better! Best bet is to try to find a used 1LE rear. Look on LKQonline.com
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
![]() ![]() Drives: 2013 Camaro 2SS/RS Join Date: Aug 2020
The 3.91 would be a good match for the 2013 L99 automatic set up?
#6 |
![]() ![]() ![]() Drives: 24 LT1 M Join Date: Oct 2015
Ya. Very good.
24 LT1 M6 Sharkskin Metallic
22 Mazda CX-30 |
#7 |
#8 |
I added them prior to my cam and TC upgrade. Definitely worth the upgrade and you'll notice a difference in the get up and go. With a big cam and high stall TC, it's hard to get traction and launch it.
22 Mazda CX-30 |
#9 |
I’ll also vouch for the 3.91s and put in a plug for the member in florida(?) that’s selling the entire 1LE cradle for a smoking price. Axles, better bushings, better suspension parts all in one! If I was to do it all over again, I’d seriously consider replacing the entire cradle. Much less work that swapping diffs, axles, bushings, etc.
#10 |
Post for the 1LE cradle for sale:
https://www.camaro5.com/forums/showthread.php?t=587440 |
#11 | |
If you can find a 1le rear that should have the stock 3.91 gears, go that route and save yourself the headaches i went thru.
