Old 09-26-2020, 11:22 PM   #1
War_Eagle
2010 RS
War_Eagle's Avatar
Drives: 2010 v6
How is this possible. Coolant temp says 243 but the needle isn’t even halfway
In the process of changing the thermostat as we speak but what would explain this. This was in traffic and quickly went back down after moving
War_Eagle is offline   Reply With Quote
Old 09-27-2020, 12:09 AM   #2
PeteD
PeteD's Avatar
Drives: 2012 2SS Victory Red with white st
Fans quit running?
PeteD is offline   Reply With Quote
Old 09-27-2020, 12:44 AM   #3
War_Eagle
2010 RS
War_Eagle's Avatar
Drives: 2010 v6
My real question is how does the temp gauge needle say I’m well below halfway but the digital dash say 243 degrees
Old 09-27-2020, 02:37 AM   #4
Machh5
Drives: Camaro
because its not real time , its computer controlled. Its done this way so people don't complain the needle is up and down all the time. If the coolant stays high the needle will eventually go up high too. TThe needle gauge doesn't show spikes, only averages over time. Try a scanner and watch the engine temp vrs the needle gauge, then you'll understand.
Machh5 is offline   Reply With Quote
