Old 10-01-2020, 03:41 PM   #1
8driann
Drives: 2012 Camaro SS 45th Anniversary
Spring question about the SS
So I know this is a long shot but my situation is that I want to lower my Camaro with springs and I didn't want to invest in some adjustable coil overs yet. My neighborhood just got some speed bumps and I don't have any Camaro friends that are lowered to come and drive over those speed bumps so I can get an idea of what size drop springs I should get. What I do have is a friend with a stock height c5 corvette and it looks pretty low but drives over the speed bumps just fine. So my question was is there a way to try and estimate a right spring size or if anyone maybe also owns a c5 and has a lowered Camaro that has compared them both and can suggest me a reasonable height that wont scrape on the speed bumps?
8driann is offline   Reply With Quote
Old 10-01-2020, 03:47 PM   #2
Bigdumogre
Bigdumogre's Avatar
Maybe just stick wiyu 1” lowering springs. Enough to make a difference but not too much that would cause problems.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 10-01-2020, 03:57 PM   #3
8driann
Yes that’s what I wast thinking, thx
Old 10-01-2020, 03:58 PM   #4
gtstorey
Straddle the speed bump and look under the car to see how close it is?
Old 10-01-2020, 03:59 PM   #5
8driann
And just measure From the lowest point of the car right?
Old 10-01-2020, 07:09 PM   #6
Avenging Orange
Avenging Orange's Avatar
Im lowered 1" and have 35 series tires...so, in a sense, I'm lowered 1.5". Also have headers. Been able to roll over small speed bumps with no issues. Its tight, but can be done...very slowly.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 10-01-2020, 08:29 PM   #7
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
I’m lowered one inch and clear speed bumps. On bigger speed bumps I occasionally hit with my off road connection pipes.
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 10-01-2020, 08:29 PM   #8
8driann
Actually now that I’m thinking about it, I might get the zl1 springs and go 35s all around.
Old 10-02-2020, 11:46 AM   #9
8driann
What size tires?
Old 10-02-2020, 11:57 AM   #10
taz1727
taz1727's Avatar
Drives: 13 Camaro 2SS/RS LS3
lowered 1.25 and i rarely bottom out. Just hit small speed bumps at an angle and you'll be alright
K&N Intake/ Pray Ported TB/ GPI Rod-Mod Intake Manifold/ GPI Ported Heads/ GPI SS3 Cam/ TSP 1-7/8" LTH to NPP/ Z/28 Diff/ Hendrix Offset Bushings/ BMR Delrin Cradle Bushings/ Pedders 27/32mm Sway Bars/ 1LE Shocks & Struts/ BMR 1.25 Springs/ Mishimoto Catch Can
taz1727 is offline   Reply With Quote
Old 10-02-2020, 11:58 AM   #11
8driann
Do you have any side skirts and/or 35’s? I will measure out the speed bumps today.
Old 10-02-2020, 12:32 PM   #12
taz1727
taz1727's Avatar
zl1 side skirts with 45's front and 35's back
Old 10-02-2020, 05:00 PM   #13
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
I'm lowered 1.25", on 19" wheels, engine lowered, and the extra weight of the Whipple...I scrape on everything.
Sent from my Pixel XL using Tapatalk
larry_g is online now   Reply With Quote
Old 10-02-2020, 07:21 PM   #14
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
I am on coilovers, 1.125” drop and 19”, 30 series tires. I have no issue at with speedbumps at my bank. Just go slow.
VR Baron is offline   Reply With Quote
camaro, drop, lowered, springs
