10-06-2020, 09:47 AM | #1 |
Drives: 2010 Camaro LLT V6, 2018 Silverado Join Date: Sep 2020
Crank Battery Voltage?
Hey everyone,
quick question, my battery reads 12.3v in the morning after an overnight shutoff. When I crank the car in the morning the voltage at the battery terminals drops to around 9.8 volts momentarily until the alternator kicks in. my question is this normal behavior? I have verified this with a multimeter and also an OBD II scanner app with graphing capabilities. I have gotten the charging system tested as good, sanded, and retorqued all the battery terminals including the starter connections. |
10-06-2020, 01:52 PM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
A quick Google search showed that a battery typically drops to 9 - 10 volts after starting the engine. Makes sense since it's pulling a few hundred amps. 14V is typical while driving.
10-06-2020, 08:38 PM | #3 |
