![]() ![]() ![]() Drives: Car Join Date: Jan 2013
AC issue...
I searched and searched....if I missed this, it wasn’t for lack of trying.
It’s rather simple. After driving a while the AC fan blows much less air. The air is still cold, but no where near enough air to cool off. Here’s the troubleshooting There’s no codes. It happens on max or no max. If you turn it off for 3-5 minutes it goes back to working fine. Freon is good to go, no leaks Compressor is fine. Clutch is engaging. (As far as I can tell) There’s no ice build up on the lines. Water falls off as usual....small to medium puddle...like always. I cleared the drain line myself and it’s good to go. Even has a new grommet. The dealership and local ac “expert” seem clueless. Thanks for reading.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Search for the blend door issue. It doesn't match your symptoms exactly, but you still may have some problem with it.
![]() ![]() ![]() ![]() Drives: 2011ss/rs camaro Join Date: Sep 2011
We have a truck at work that the ac freezes after it’s run for a while. Carried it to Ford. They couldn’t fix it. It works great at cooling..just freezes occasionally. Turn the compressor off for 5 minutes and she’s good, til it freezes up again. When it freezes it blocks airflow from fan. I realize this doesn’t fix yours, but we learned to live with it.
'Maro
Drives: 2015 SS 6.2L Auto 2SS Join Date: Sep 2016
Hopefully it's not the blend door. I just got mine back today, thankfully it was covered under an extended warranty I have. They had to remove the windshield and the dash but they did a great job.
2015 SS 2SS Auto 93 SCT Perf, Kooks LTH & HFC MBRP Axleback Muffler Delete "Z/28" Spoiler and Grille OEM ZL1 wheels 285/305/35R20 BFG G-force Pro Comp 2
#6 |
![]() ![]() ![]() Drives: 2011 Camaro 2LT/RS Join Date: May 2015
cabin air filter clear? blower resistor module?
#7 | ||
^^^^THIS! LOL It’s not the blend door... |
#8 |
Drives: Camaro Join Date: Jun 2020
Most likely the Charge is on the low side or the expansion valve<bet thats your trouble.
#9 |
