Old 10-08-2020, 05:59 PM   #1
michaeltk
michaeltk's Avatar
Drives: 2010 Chevy Camaro 2SS/RS
Rim size?
I have basically the whole BMR suspension kit (lowered 1 1/4") as well as koni sports (yellow). I am looking to go down to a smaller weld rim.
Thinking 18 or even 17. What width would work in my application? 18x10.5? 18x11? 17x? I'd like to try and fit a 315 tire in the rears and something like a 275 in the fronts.
Any help is greatly appreciated.
michaeltk is offline   Reply With Quote
Old 10-10-2020, 06:54 PM   #2
michaeltk
michaeltk's Avatar
bump
Old 10-10-2020, 11:09 PM   #3
Army of Wuzzy
Army of Wuzzy's Avatar
Drives: 2011 Chevrolet Camaro LS
Originally Posted by michaeltk View Post
bump
Do you have brembos
"If you aren't first, you're last"
-Ricky Bobby
Army of Wuzzy is offline   Reply With Quote
Old 10-11-2020, 12:39 AM   #4
Athletics101
Athletics101's Avatar
Drives: 5th Gen L99
Depends on your goals for the car. You can fit 17’s and 18 on the rear. Depends on the wheel tho, the angle of the spokes will hit the Brembos on a few 17” set ups. If you care about fitment at all welds are not the way to go and either is a 17”. Again depends on the goal of the car. I’d figure out the end HP goal, and buy a wheel and tire package based on that. So you don’t end up buying them again down the road.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
Athletics101 is offline   Reply With Quote
Old 10-11-2020, 10:00 PM   #5
mikeman
Banned
Drives: 2015 Camaro
I wouldn't go smaller than 18" unless you're racing at the track. Once you go less than 18", the rims and tires start to look funky on a thick bodied car like the 5th gen. Just my opinion, of course.
mikeman is offline   Reply With Quote
Old 12-27-2020, 09:03 PM   #6
michaeltk
michaeltk's Avatar
Basically looking to go with 18” welds all the way around I was just looking for some clarification on the width. 9? 9.5? wanting to put 315’s in the rear and something like 275’s in the front
Old 12-28-2020, 07:02 AM   #7
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
I am running 315’s in the rear with 11” wide wheels. They are 20’s but that shouldnt make a difference.
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
rims, suspension, tires, weld
