![]() Drives: Chevy Camaro 2015 2SS RS Join Date: Feb 2020
playing through Spotify while plugged?
Hi everyone, whenever I play music through bluetooth it works with spotify, but once I plug my phone into a charger it forces it into "iPod" mode and shows "no music found". I am then unable to continue to listen on Bluetooth when charging.
Is this a common problem? and How can i solve it? thank you! |
![]() ![]() ![]() Drives: 2014 2SS/RS Join Date: Dec 2014
Instead of plugging the charge cord into the car USB port to charge ...I plug it into the cigarette lighter outlet to get the charge power. This prevents the car from trying to pull data via USB port and only pulls the data via Bluetooth. Which eliminates the annoying no music found message.
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
Thank you!
just use a cigarette lighter plug and not the usb you it will work like a charm. i keep my phone in center console while charging and streaming bluetooth.
David Vianu
2010 Synergy Green 1LT |
Drives: Chevrolet Camaro Join Date: Sep 2022
I had a similar issue with Spotify and my phone when it came to charging and Bluetooth. But I recently discovered some hidden gems about Spotify that might help you out! I found this website streamingfamous.com that, has some great tips and tricks for getting the most out of your Spotify experience.
As for your issue, I found that instead of plugging the charge cord into the car USB port to charge, I plug it into the cigarette lighter outlet to get the charge power. This prevents the car from trying to pull data via a USB port and only pulls the data via Bluetooth. Which eliminates the annoying "no music found" message. Last edited by ailinmeter; 05-04-2023 at 10:05 AM. |
#6 |
![]() Drives: BMW Join Date: Jul 2023
I totally get your frustration with charging. It's like, "Why you gotta switch to 'iPod' mode, phone?" I've been there too.It's not super common, but it happens to a few of us. The solution might be a bit of a workaround. Try putting your phone in "Do Not Disturb" mode before plugging it in. This can sometimes prevent the switch to "iPod" mode and let you keep jamming on Bluetooth while charging.And hey, if you're still looking for solutions, here's a random thought: have you ever considered boosting your music's reach with Spotify plays? I found out that you can buy Spotify plays, which can be helpful.
#7 |
![]() Drives: Camaro Join Date: Apr 2023
Does someone know what Spotify plays can give you?
#8 |
I've experienced a similar issue before. Try checking your phone's settings to see if there's an option to prioritize Bluetooth audio even when charging. Also, make sure your Bluetooth device is properly paired and that there are no interruptions in the connection. And by the way, a site where you buy Spotify plays could potentially boost your visibility, giving your music a wider audience!
#9 |
![]() Drives: 2011 Join Date: Sep 2017
I know on my Samsung it happens to me.As soon As i plug it in it will go to auto mode..I had to clear the data on the app
And redo the settings to allow phone calls and music |
| Tags |
| bluetooth, charger, infotainment, music, spotify |
