Old 10-10-2020, 01:21 PM   #1
Aqwk68
Aqwk68's Avatar
Drives: 2010 2ss/rs and turbo 68 camaro
2012 oil leak
I've noticed an oil spot under the camaro and when I got under there, I could see a line come down the passenger sides trans from the top. I can't see or feel any obvious locations its coming from above the trans. Valve cover gaskets are dry nothing from heads and block. Any thoughts on where it could be coming from? Would a rear main seal leak like this from above theatrics? I wouldn't think so, but leaks are crazy. Car is a manual with whipple. Trying to get some ideas of what can be causing it.
Aqwk68 is offline   Reply With Quote
Old 10-10-2020, 08:34 PM   #2
Vegas Bound
Drives: 2013 Sparkly Red One
Rear main or oil pressure sensor. Your boost may have blown one or the other out.
Vegas Bound is offline   Reply With Quote
Old 10-10-2020, 09:27 PM   #3
Aqwk68
Aqwk68's Avatar
Thanks. Is the oil pressure sensor on the back of the block like the other ls engines or is it somewhere else? I'll give the sensor a check since it should be easier to see.
Old 10-10-2020, 10:54 PM   #4
Vegas Bound
Yes
