View Poll Results: Which looks better?
Black pods 15 60.00%
Silver pods 10 40.00%
Voters: 25. You may not vote on this poll
Old 10-13-2020, 11:06 AM   #1
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Question Which do you prefer?
Personally I prefer the black pods because the gauges are black. But I can see guys with chrome or silver gauges leaning the other way.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 10-13-2020, 11:15 AM   #2
brick59
Sucker Punch
brick59's Avatar
Drives: 2013 Black ZL1, 2022 Silverado ZR2
Black, I think it will blend in better but everyone is going to have there own opinion. its going to be what you like that matters.
427 Dart SHP Pro LS Block, Callies Magnum Crank, Callies Ultra I Beam Rods, Diamond Pistons, AGP twin Turbos 6865, Mast heads, Cam Motion LLR cam, Morel tie bar lifters, Crower roller rockers, NW 103MM TB, ID2600 XDS, Fore Triple, DSX, E85, ARH Turbo Headers, Corsa, Jakes stage 5 4L80, Circle D, RPM Roll Bar, BMR, Carlyle Racing 15" conversion kit.
brick59 is offline   Reply With Quote
Old 10-13-2020, 11:38 AM   #3
Inferno dogg
Inferno dogg's Avatar
Drives: 2010 Camaro 2SS
definitely the black ones!!
GPI SS3 cam with top end goodies,Circle D 4c 3800 w/Tru-Cool 4000,3.90 yukon gears,Kooks long tube headers,Roto fab cold air intake, Corsa extreme 3" cat back, Dyno tuned by Andrews Auto Georgetown MI, Heritage Grille, T4 splitter with under tray, Anvil spoiler,MRR 228 reps with Nitto NT555G2 tires 315 rear 275 fronts,BMR poly bushings,HD Diff cover from RDP,Raytech install kit
Inferno dogg is offline   Reply With Quote
Old 10-13-2020, 11:41 AM   #4
spyderbuddy
paint your bezel black and that would work
Old 10-13-2020, 11:42 AM   #5
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
My AEM gauges came with a silver bezel so I used those with the silver pods. Still like yours better.
Sent from my Pixel XL using Tapatalk
Old 10-13-2020, 03:03 PM   #6
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Where did you get those pods?
They look like they're poking out the bottom.
FasNuf is offline   Reply With Quote
Old 10-13-2020, 03:09 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Black for sure. Looks better, silver would be "too much" silver in there. You want a little contrast. But it all depends on what YOU like.
Old 10-13-2020, 03:15 PM   #8
TheFlyingBananaSS
The pods are all 2 inch pvc pipe. Cut to desired size. The black pods are 3/4 of an inch shorter than the silver set. With AEM gauges you can use a very short pod because the gauge only goes in the pod about 3/8 inch. The black set are more refined from experience I gained making the silver set.
Old 10-13-2020, 03:18 PM   #9
TheFlyingBananaSS
Oh, in case anyone needs it I'll be selling my A pillar duel pod setup. Brand new never used. PM for details.
Old 10-13-2020, 04:23 PM   #10
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Black pods look better to me. Just my two cents
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 10-13-2020, 07:26 PM   #11
witenite
witenite's Avatar
Drives: 2010 2SS non RS
Both looks good. With that said I voted black.
witenite is offline   Reply With Quote
Old 10-13-2020, 08:08 PM   #12
Sparko
Sparko's Avatar
Call me crazy, but I think the silver buckets looks way better. I think it punctuates the gauges, and it looks like it belongs as part of the bezel. Black buckets looks like someone hot glued them onto their '97 Accord.
2010 Camaro 2SS
2018 Charger GT+
2005 Cavailer LS S/C - Sold
'87 HD FXRT - Wrecked pending repair
Sparko is offline   Reply With Quote
Old 10-13-2020, 08:13 PM   #13
Spec
Drives: 2010 Camaro 1SS LS3
Voted for the black ones as I'd follow with a CF bezel...
Spec is offline   Reply With Quote
Old 10-13-2020, 08:14 PM   #14
FasNuf
FasNuf's Avatar
Thanks Flying Banana for letting me post this quick classified as it pertains to this thread.
I bought a bezel used and decided not to use it. It's in excellent condition and I'm just looking to make my money back if you're looking for one.
$15 + freight.
