Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Transmission / Driveline
Old 10-14-2020, 02:02 PM   #1
blvckZL1
blvckZL1's Avatar
Drives: 2013 Camaro ZL1
WTB ZL1 Clutch
Looking for a clutch or clutch kit that fits a 2013 ZL1, thanks.
blvckZL1 is offline   Reply With Quote
Old 10-14-2020, 07:30 PM   #2
AresSupersport
Drives: 2010 Camaro SS
I have a McLeod RXT twin disc clutch with about 500 miles on it plus some dyno time. Still in great shape. I'd sell it for 500 plus shipping
AresSupersport is offline   Reply With Quote
Old 10-14-2020, 08:23 PM   #3
TuneAFish
TuneAFish's Avatar
Drives: 2015 Camaro SS M6
Do you need a different flywheel with that clutch or does the stock SS flywheel work?
Separate question: I know in some cases (like gears) all-out drag racing gears are softer than street gears so they don't explode at maximum stress, but because of that they wear out faster if driven on the street. Are racing clutches like this the same; good for holding the power but wear out quicker? Just trying to learn a little from people that have actually used them.
-Rad Air CAI
-GPI SS3 Cam & BTR Springs
-2" Texas Speed Headers
-AEM Wideband AFR
-3" Full Exhaust w/Hi-Flow Cats & Single Chamber Flowmasters
-McLeod RXT twin-disc w/Aluminum Flywheel
-Yukon 4.11
-Nitto 555 G2
TuneAFish is offline   Reply With Quote
Old 10-15-2020, 08:22 AM   #4
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
LSA and LS3 require different flywheels due to different bolt patterns on the crank.
