Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Transmission / Driveline
Old 10-15-2020, 04:08 PM   #1
BadAquaBluSS
H-Town Camaro Club
BadAquaBluSS's Avatar
Drives: 2010 ABM 1SS/RS, Red 85 Z28
Ideal Garage Clutch Master
Anyone have an Ideal Garage Clutch Master that they've removed from their car or haven't installed that they would like to sell I would really like to have one. thanks
AGP Twin Turbo, RPS Triple Carbon Clutch, ZL1 Diff with 3.73 gears and Kooks 3" Stainless Steel Exhaust with X Crossover, Kooks Stainless Steel Mufflers, Go Fast Bits EBC, AEM Methanol injection and AEM gauges UEGO and Fuel pressure, Livernois's dual fuel pump, KB Boost a Pump, AUS 1000cc injectors, Full BMR suspension with Koni shocks, JDP Color Changing Halos, Color Changing Scanner Light Bar and Rockford Fosgate T Series Amp's Kicker L7 Sub's.
Build Thread:
http://www.camaro5.com/forums/showthread.php?t=400372
BadAquaBluSS is offline   Reply With Quote
Old 10-15-2020, 11:09 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
https://www.camaro5.com/forums/showt...aster+cylinder
Orange Krush II
Old 10-16-2020, 06:57 AM   #3
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
I do. Message me. Brand new in box.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter, SS brake lines ZLI calipers, rotors/pads BMR Trailing & Toe Arms, rear cradle/diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers, HF cats, GMPP axle back, Elite Eng Catch Can, Black ZL1 20x10 & 2011 whls 285/35/20 & 305/35/20 General G-Max RS, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console, hand brake lever, Grant steering whl.
flht99b is offline   Reply With Quote
Old 10-16-2020, 08:59 AM   #4
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
May want to consider Ticks new adjustable master
https://www.tickperformance.com/tick...4-17-chevy-ss/
camguynj is offline   Reply With Quote
Old 10-29-2020, 09:45 PM   #5
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
I do have a Tick adj 5th gen master for sale..installed and taken out. 0 mile on it.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 10-29-2020, 11:02 PM   #6
camguynj
camguynj's Avatar
Taken out 0 miles ...may I ask why ?
Old 10-30-2020, 12:24 AM   #7
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
I went with a custom Mini Twin and the pedal travel is halves, so not compatible with this clutch. I am sure this is the only exception.
13' 1LE
