Old 10-20-2020, 07:22 PM   #1
hudson773
Drives: 2014 camaro SS
recommendations for short throw shifter
looking to upgrade my stock shifter.
hudson773 is offline   Reply With Quote
Old 10-20-2020, 07:24 PM   #2
Rob3D
Rob3D's Avatar
Drives: Car
MGW
Rob3D is offline   Reply With Quote
Old 10-20-2020, 07:36 PM   #3
gsxrturbo
Drives: 2010 ss
mgw
gsxrturbo is offline   Reply With Quote
Old 10-20-2020, 07:48 PM   #4
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
MGW
Sent from my Pixel XL using Tapatalk
Old 10-20-2020, 08:18 PM   #5
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
MGW with a weighted shift knob.
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 10-20-2020, 08:40 PM   #6
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
I love my Barton....
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 10-20-2020, 09:16 PM   #7
fz4k98
Drives: 2013 1ss
Weighted shift knob? What does it do? I have the MGW and it helps with my 2-3 shift misses.
fz4k98 is offline   Reply With Quote
Old 10-20-2020, 09:20 PM   #8
Sinister10
Sinister10's Avatar
Drives: 2010 Camaro SS
mgw..a little pricey, but worth it
2010 2SS/RS 6M, MGW flatstick, CAI cold air intake, SLP loudmouth 2 axleback, TSP 1 7/8 headers w/ hfc, pfadt 1" springs, SRP pedals, emblempros "6.2L" emblems on hood, ZL1 grill, M/T SC-5 wheels, nitto motivo 275f 315r. ZL1 addons wickerbill, smoked lenses, resonator delete x pipe, diode dynamics DRLs 1LE suede steering wheel, mighty mouse CC. SCTX4 and Dyno Steve tune.
Sinister10 is offline   Reply With Quote
Old 10-20-2020, 09:55 PM   #9
Camaro2ss2010
I drove with a normal shift knob for a year cause I didn’t want to spend $75 or more on a shift knob. Changed it about two weeks ago and wish I would’ve done it to begin with. It takes the “notches” out of the shifts.
Old 10-20-2020, 10:14 PM   #10
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Mgw
Old 10-21-2020, 12:20 AM   #11
oldman14ss
Drives: 2014 1ss camaro
mgw
oldman14ss is offline   Reply With Quote
Old 10-21-2020, 01:17 AM   #12
fireman1153
Another vote for MGW with weighted knob.
2010 Camaro 2SS/RS - 416 stroker, F1A-94 procharger, BTR blower cam, Big Red race valve, AGP intercooler, Alky dual nozzle kit, ZL1 fuel pump with DSX Aux pump, DSX flex fuel sensor, Bosch 210 injectors, Mcleod RXT1200 clutch, MGW flat stick, Tick Performance Level 3 trans, DSS 3.5 aluminum driveshaft, Strange S60 rear, DSS 1400hp axles, Texas speed 1 7/8 headers, X-pipe and MBRP muffler delete, BMR lowering springs, BMR trailing arms and toe rods, Poly motor mounts, RevShift trans mount instert, rear sub frame braces, Tuned by Joey at Pure Fabrication in Panama City, FL
fireman1153 is offline   Reply With Quote
Old 10-21-2020, 01:34 PM   #13
sscamaro
Drives: 2010 2SS, 2017 Silverado LTZ
Hurst Billet Short throw Shifter. 44% shorter throw than stock shifter.
sscamaro is offline   Reply With Quote
Old 10-21-2020, 01:45 PM   #14
mikeman
Banned
Drives: 2015 Camaro
For a manual, I would recommend MGW.
mikeman is offline   Reply With Quote
